Solid Edge nifty features
Jaylin Hochstetler
x 380
x 355
Re: Solid Edge nifty features
Jaylin Hochstetler wrote: Mon Nov 08, 2021 7:42 am Here is a video showing the different steering wheel commands (Extend/Trim, Lift, and Tip). Understanding how these work is very valuable when working in Sync.
Here is a help topic on it that does a good job of explaining the differences.
https://docs.sw.siemens.com/en-US/produ ... verotate1d
Attached is a really handy poster I keep on my desk regarding steering wheel shortcuts and relationships.
Solid Edge QRC.pdf
(278.05 KiB) Downloaded 283 times
mike miller
x 1070
x 1231
Unread post by mike miller »
I just discovered this today. Horizontal/Vertical face relationships can be defined by the orientation of reference planes, including from Csys.
SE face relationships.mp4
(9.6 MiB) Downloaded 315 times
mike miller
x 1070
x 1231
Something I discovered a long time ago, but really came to appreciate recently: Occurrence Properties. This is somewhat like SWX Component Properties in an assembly, but way more powerful.
You can add your own columns, configure them with dropdowns, set defaults, and even create custom tooltips. All the settings are controlled by a .XML file that can be stored centrally.
:shock:
Edit to add: Forgot to mention- this is also where you tell the software whether or not to show an occurrence/instance on a drawing and/or a BOM, calculate physical properties in the assembly, analyze interference, display in a higher level assembly, override the quantity, and allow it to be selected in the assembly. Now for the cream on top: custom attributes like BOM ID, Notes, etc. can be set as local or global inside the .XML file. Local means "make it apply in this assembly only". Global means "make it propagate upward so higher levels can see it too".
Also, if an occurrence is underdefined, you can position its translation and rotation using the coordinate values.
All this in one place. I like it.
x 1225
x 2390
I like the "Lock Rotation" options in mate dialogs. Much simpler than the SW methods.
x 2568
x 1420
matt wrote: Thu Dec 23, 2021 11:46 am I like the "Lock Rotation" options in mate dialogs. Much simpler than the SW methods.
UU
One single like is not sufficient.
Answers: 32
x 1246
x 2034
I guess I'm missing something, how is it different? In SW it's check box instead of two buttons. In the popup or Property Mgr.
x 1225
x 2390
jcapriotti wrote: Thu Dec 23, 2021 10:56 pm I guess I'm missing something, how is it different? In SW it's check box instead of two buttons. In the popup or Property Mgr.
That wasn't always there. And it's very un-SW-like anyway. ;)
Answers: 32
x 1246
x 2034
matt wrote: Fri Dec 24, 2021 9:18 am That wasn't always there. And it's very un-SW-like anyway. ;)
In the popup it must've been added a version or two ago, either 2021 or 22. It's been in the property editor for several versions.
Perhaps inconsistent in GUI? The mate alignment below it is two buttons like SE. Although the SE options are opposite with the "Lock" as two buttons and "Flip" as a single selection.
mike miller
x 1070
x 1231
Here's something you might not have known. (in fact, I didn't know it until very recently)
Selecting multiple faces and editing a PMI dimension will move all those face with each other as a group.
PMI multiple selections.mp4
(3.97 MiB) Downloaded 243 times
x 1780
x 2143
You're still doing it the hard way. I mate a bunch of components, then right-click on the Mates folder and lock all of the concentric mates at once.
Before:
After:
x 2282
x 1921
The last time I used NX (2017) a cylindrical constraint, and a cylindrical constraint without rotation were two separate mates. There was no easy way to switch between the two. (Or if there was, noo one inn our group was aware of it.)
x 2568
x 1420
SPerman wrote: Tue Jan 18, 2022 3:33 pm The last time I used NX (2017) a cylindrical constraint, and a cylindrical constraint without rotation were two separate mates. There was no easy way to switch between the two. (Or if there was, noo one inn our group was aware of it.)
I don't know anything about NX but since this is the SE nifty thread and if I understand what you're asking; this was a very nifty feature enhancement somewhere along the way. I don't recall when it was added.
Answers: 32
x 1246
x 2034
Glenn Schroeder wrote: Tue Jan 18, 2022 3:02 pm You're still doing it the hard way. I mate a bunch of components, then right-click on the Mates folder and lock all of the concentric mates at once.
Nice tip.
Not sure when it was added but in 2022, toolbox parts can be automatically set to lock concentric mates. Wonder if that can be applied to non-toolbox parts if you set the toolbox flag on them.
x 2282
x 1921
I finally found it in their help.
