Weldment profile sorting all wrong!!!
IndianaDave
x 5
x 57
Unread post by IndianaDave »
I'm not sure if a Windows update did this or not, but our weldment profiles sort differently, now... Seems to have happened the week before last.
In this example, all of the 0.25 x 2, 2.25,2.50,2.75 used to be all together sequentially.
Now the nominal sizes are together, and then the fractional are down lower.
Of course, our VAR blames Windows...
x 1777
x 2142
Re: Weldment profile sorting all wrong!!!
Try going to the configuration tab, right-clicking on the file name at the top, and going to Tree Order. Try out different options. If neither of the first ones do what you want (and I don't know if they will), try the Manual option, which I know will be tedious, or add a zero in your configuration names where needed so they'll sort correctly.
KevinC
x 17
x 70
Unread post by KevinC »
What you're looking for is called numerical sorting.
Which sorting method happens in a File Explorer window?
Is it like your OP image?
Perhaps Windows sorting got change somehow.
Windows is numerical by default, I believe and it's a reg edit to change it.
https://www.tenforums.com/tutorials/914 ... -10-a.html
