How would I convert this part to sheet metal?
Mike Gera
x 93
x 36
Unread post by Mike Gera »
I'm struggling with the attached part.
I need to convert it to sheet metal so that I can generate a flat pattern for the blank.
Any ideas?
Any help would be greatly appreciated!
CTSM.SLDPRT
(90.43 KiB) Downloaded 360 times
SW 2024 SP 5.0
Windows 11
x 2568
x 1420
Re: How would I convert this part to sheet metal?
what version of SW is that saved in? I cannot open.
x 1654
x 1489
Remodel it in sheetmetal. It'll take longer to "convert".
Mike Gera
x 93
x 36
bnemec wrote: Tue Mar 01, 2022 12:06 pm what version of SW is that saved in? I cannot open.
2021 SP 5.1
SW 2024 SP 5.0
Windows 11
Mike Gera
x 93
x 36
Frederick_Law wrote: Tue Mar 01, 2022 12:15 pm Remodel it in sheetmetal. It'll take longer to "convert".
I tried to but couldn't figure out how.
SW 2024 SP 5.0
Windows 11
SamSpade
x 223
x 158
Unread post by SamSpade »
Your part doesn't seem to have any sheet metal operations (no break forming or roll forming). Looks like something that would require a stamping operation or something similar. You can try creating a conic surface and then flattening that.
Lucas
x 171
x 169
Unread post by Lucas »
Try using this method:
gupta9665
Answers: 26
x 442
x 460
Unread post by gupta9665 »
You can use the swept flange as well.
HerrTick
x 32
x 307
Unread post by HerrTick »
So you have a feature called "halving cut" that doesn't actually cut the feature in half. That's problem number 17.
Why not just make a 180° revolve?
If you make the cut edges through the center axis you get a straight edge that can be used in the convert operation.
HerrTick
x 32
x 307
Wait... you won't have a straight edge. This is a revolved arc, resulting in a torus. Can not convert.
Mike Gera
x 93
x 36
gupta9665 wrote: Wed Mar 02, 2022 5:08 am You can use the swept flange as well.
Hey Deepak,
I tried that this morning. File attached. It will not let me flatten.
Any ideas?
Thanks for your help!
swept_flange_test.SLDPRT
(97.69 KiB) Downloaded 206 times
SW 2024 SP 5.0
Windows 11
HerrTick
x 32
x 307
Before you waste too much more time trying to flatten...
WHY must you flatten? Are you building the tool? Are you purchasing flats to form in-house?
If someone else is building the tool, don't do the flat for them. Good toolmakers have better tools for the job. Poor toolmakers don't have the right tools for... most things. The best toolmakers won't even look at your flat.
Mike Gera
x 93
x 36
HerrTick wrote: Wed Mar 02, 2022 6:38 am So you have a feature called "halving cut" that doesn't actually cut the feature in half. That's problem number 17.
Thanks. I tried that. It gives me a "No bends found." error.
SW 2024 SP 5.0
Windows 11
Lucas
x 171
x 169
Mike Gera wrote: Wed Mar 02, 2022 1:34 pm Hey Deepak,
Any ideas?
The problem is that you are using an arc as a profile, it must be a line.
swept_flange_test_fix.SLDPRT
(88.27 KiB) Downloaded 302 times
Lucas
x 171
x 169
Loft-Bend makes a different Flatten geometry. (I converted the inner arc into a sketch for it and deleted the body)
swept_flange_test_loft.SLDPRT
(109.29 KiB) Downloaded 303 times
gupta9665
Answers: 26
x 442
x 460
Any ideas?
I would go with what @Lucas has already stated. Hope that helps.
HerrTick
x 32
x 307
Be careful substituting a loft for a revolve. You are substituting a tolerant feature (B-surface) for an analytic (torus). You may come close, but never exact. Up to you to decide how close is close enough.
