How would you make it?
Yep, but it gets suppressed when folded back lol
That worked, thanks. Will keep in mind to split into more featuresjcapriotti wrote: ↑Wed Mar 30, 2022 8:01 am How to make it depends on its use. It it needs to mate up to another part very precisely, then you may have to cut it post bending as that surface would not be normal. If you don't have that requirements, then a side cut with "Normal Cut" checked is the way to go.
