Fillet on Sheet Metal Bend
Lucas
x 171
x 169
Unread post by Lucas »
I am having trouble to replicate those fillets, on the original part it actually looks like the cut was made after the bends... o[
How would you make it?
Cover in2.SLDPRT
(242.96 KiB) Downloaded 164 times
by jcapriotti » Wed Mar 30, 2022 8:01 am
How to make it depends on its use. It it needs to mate up to another part very precisely, then you may have to cut it post bending as that surface would not be normal. If you don't have that requirements, then a side cut with "Normal Cut" checked is the way to go.
Cut from side, Normal Cut selected
Lucas
x 171
x 169
Re: Fillet on Sheet Metal Bend
Update: Checking the Normal Cut on the Extruded Cut makes a better result, maybe I need to reposition the fillets
SamSpade
x 224
x 160
Unread post by SamSpade »
Have you tried a normal cut without the fillets, and then unfolding the part and adding the fillets afterward? I haven't tried it to know for sure it would work, but it just might give you a better-looking blank.
Answers: 32
x 1272
x 2066
Lucas
x 171
x 169
SamSpade wrote: Wed Mar 30, 2022 7:51 am Have you tried a normal cut without the fillets, and then unfolding the part and adding the fillets afterward? I haven't tried it to know for sure it would work, but it just might give you a better-looking blank.
Yep, but it gets suppressed when folded back lol
Also adding the Fillet Feature on sheet metal seems to be a bad practice, perhaps even on the Sketches...
Anyway, thanks for the reply UU
jcapriotti wrote: Wed Mar 30, 2022 8:01 am How to make it depends on its use. It it needs to mate up to another part very precisely, then you may have to cut it post bending as that surface would not be normal. If you don't have that requirements, then a side cut with "Normal Cut" checked is the way to go.
That worked, thanks. Will keep in mind to split into more features UU
x 227
Unread post by Dwight »
Lucas wrote: Wed Mar 30, 2022 7:30 pm
Surely that's not the case. I have used both sketch and feature fillets with sheet metal with no issues for years.
Lucas
x 171
x 169
Dwight wrote: Thu Mar 31, 2022 10:36 am Surely that's not the case. I have used both sketch and feature fillets with sheet metal with no issues for years.
Yep, forget to mention specifically on bends. ^^
