Generic Pet Peeves
- x 1780
- x 2143
Generic Pet Peeves
There is already one for Solidworks, but sometimes we have things get under our skin that are unrelated to software. It's generally the organic beings we interact with.
Here's my first example. It's clients that send us pdf's with drawings, and they need to be rotated before I can read them. Yes, I know it's not that difficult for me to rotate them, but it boggles my mind that someone would send out a drawing that way. I couldn't do it.
- x 1654
- x 1489
Re: Generic Pet Peeves
People leave voice msg: "Call me"
The guy who is ruining the morale of the good employees because he brags about how little he actually does during the day. (And the boss who won't fire anybody, for any reason.)
- the_h4mmer
- x 106
- x 80
When people go against their word
- x 1246
- x 2034
When you attend a meeting and are asked if there is an issue moving a server to Azure, and they tell you it must be moved, no exceptions?
And now we have issues.......
- x 1780
- x 2143
Well at least they asked.jcapriotti wrote: ↑Thu May 05, 2022 11:26 am When you attend a meeting and are asked if there is an issue moving a server to Azure, and they tell you it must be moved, no exceptions?
"Why can't I email .exe files? The IT department just makes up stupid rules for no good reason."
(Edit: That is the grief I get from others. Not my view.)
- x 2489
- x 1899
Glenn Schroeder wrote: ↑Tue Apr 26, 2022 3:37 pm There is already one for Solidworks, but sometimes we have things get under our skin that are unrelated to software. It's generally the organic beings we interact with.
Not only are you, Matt, the answer to that question, but you are the answer to so many more!
- - -Randy Pausch
- - -Randy Pausch
- x 2489
- x 1899
- x 1246
- x 2034
Because you are a danger to yourself. The next step is to stop all EXEs from executing and move everything to the harmonious cloud where there are no more files for you to hurt yourself with.mattpeneguy wrote: ↑Fri May 06, 2022 2:54 pm Even worse, why can't I open .exe files in the emails I receive?...
Cross threaded twist ties. It should tighten clockwise, like a screw.
- x 1780
- x 2143
When someone is driving 5 mph under the speed limit, and won't move out of the left lane, it should be legal to run them off the road.
I am about to drive home in the rain, which means everyone on the interstate will be driving 40 mph, with their flashers on, in all 4 lanes.
I have no problem if you are afraid of driving on wet roads, but please, get the heck out of the far left lane.
- x 1654
- x 1489
I can send you a reg file to block all exe files.jcapriotti wrote: ↑Tue May 10, 2022 10:27 am Because you are a danger to yourself. The next step is to stop all EXEs from executing and move everything to the harmonious cloud where there are no more files for you to hurt yourself with.
You'll be surprise how many IT didn't block running of reg file.
- x 1654
- x 1489
- x 1246
- x 2034
Our company approach now is to block everything, then only unblock selective stuff based on what needs it. More secure I suppose, but business slows to a crawl as you have to open tickets and justify every change. The red tape get thicker and thicker.Frederick_Law wrote: ↑Thu May 12, 2022 5:25 pm I can send you a reg file to block all exe files.
- x 1654
- x 1489
If you see your computer has Sophos, good luck. It default to block everything. It was blocking Soildworks bug report because of .ASPX or something like that in web connection. Took them a few days to figure out how to unblock it.
- x 1246
- x 2034
Haven't seen that one but our PCs have Win Defender, McAfee, and Carbon Black. When something stops working or works very slowly it becomes a game of hunt for the offending antivirus software. Had a couple of PDM reports that are run from EXE files that went from 5 seconds to 5-10 minutes. Windows Defender was the culprit but no one could tells us why or how to fix it. Not every PC would exhibit the behavior either.Frederick_Law wrote: ↑Thu May 12, 2022 6:36 pm If you see your computer has Sophos, good luck. It default to block everything. It was blocking Soildworks bug report because of .ASPX or something like that in web connection. Took them a few days to figure out how to unblock it.
- x 1654
- x 1489
Check extension of the report file. Add it to exception.
CAD program like to create a temp file first and rename it at the end.
So the temp file could have another extension.
If possible, add all CAD file extension to exception.
Also where does the EXE create file, local or server?
- x 1246
- x 2034
It doesn't create any files. It resides on a server and we have PDM buttons on the data cards that launch them. The report is generated at runtime. The GUI takes 5 minutes to come up, not the report running part, which is normal once the programs opens.Frederick_Law wrote: ↑Mon May 16, 2022 8:45 am Check extension of the report file. Add it to exception.
Also, we can't just add exceptions. We must open a ticket which has to get approved so an outside company can make the changes. It was all so simple when we handled this internally. Now we work with outside companies to become more secure.
There was a time, back in the ancient days of computers, where the OS didn't try and "help" you select text. You put the cursor where you wanted the selection to begin, and drug it to where you wanted the selection to end. I hate the fact that Windows decides it knows what you want to select. 95% of the time it is wrong, and takes much effort to only select the text I want.
- x 1780
- x 2143
We use Outlook for email here. It's especially bad about that.SPerman wrote: ↑Thu May 19, 2022 7:53 am There was a time, back in the ancient days of computers, where the OS didn't try and "help" you select text. You put the cursor where you wanted the selection to begin, and drug it to where you wanted the selection to end. I hate the fact that Windows decides it knows what you want to select. 95% of the time it is wrong, and takes much effort to only select the text I want.
- x 818
- x 998
I have resorted to using SHIFT + arrow keys to select text.Glenn Schroeder wrote: ↑Thu May 19, 2022 8:23 am We use Outlook for email here. It's especially bad about that.
- Jaylin Hochstetler
- x 380
- x 355
Why did my screen go blank and say "Pay $2000 to regain access to your computer" when I opened a .exe on a email I received?....mattpeneguy wrote: ↑Fri May 06, 2022 2:54 pm Even worse, why can't I open .exe files in the emails I receive?...
- Ömür Tokman
- x 995
- x 347
Change your extension and leave a note.
"Please change the extension to exe"
Who cares about the rules. (don't let the boss hear!)
Not:I am currently using this method.
- x 1231
Just discovered this by experimenting with it.SPerman wrote: ↑Thu May 19, 2022 7:53 am There was a time, back in the ancient days of computers, where the OS didn't try and "help" you select text. You put the cursor where you wanted the selection to begin, and drug it to where you wanted the selection to end. I hate the fact that Windows decides it knows what you want to select. 95% of the time it is wrong, and takes much effort to only select the text I want.
Click. Hold ALT. Drag your selection and it won't jump to whole words.
- x 1780
- x 2143
About 10:30 this morning I got a pop-up that Solidworks couldn't connect to the server, and it shut down. I checked with a coworker, who reported the same issue. I immediately called IT, told the guy what had happened, and that the problem was on their end. He logged into my computer and pharted around for about four hours, and then told me the problem was on their end.
- x 1654
- x 1489
Same thing when I contact reseller.
Usually I'll test laptop on cell network to make sure it's SW problem.
- x 1780
- x 2143
At least it was fixed yesterday morning when I got to work.Frederick_Law wrote: ↑Tue Jul 26, 2022 8:20 am Same thing when I contact reseller.
- x 1780
- x 2143
While I generate most of the drawings we use here to construct the test installations, we sometimes get drawings from the client. They want to save money and have them done in-house. The quality is often "questionable".
Our construction supervisor just showed me a set and said there seemed to be a discrepancy between the drawing views and the BOM quantities. What did I think he should do?
My answer: "Do nothing until you get clarification from the client. Make no assumptions."
- x 818
- x 998
I absolutely hate it when I (or another designer here) have made a mistake and the vendor sees that mistake and then makes an assumption as to what I might have meant, and then moves on with the $10,000+ project without picking up the phone or sending an email.Glenn Schroeder wrote: ↑Fri Aug 05, 2022 10:48 am While I generate most of the drawings we use here to construct the test installations, we sometimes get drawings from the client. They want to save money and have them done in-house. The quality is often "questionable".
People who do that more than once will lose their business from me. I don't care how hot the project is.
Everyone makes mistakes....but if you see one....call it out....find out why or what or who...
There should be an international standard for Pan/Tilt/Zoom mouse key combinations.
- x 1780
- x 2143
I agree, and Google maps has it backwards. Rolling the wheel toward you should zoom in. And that's not just because I'm prejudiced toward the default behavior with Solidworks. It seems counterintuitive to me to roll the scroll wheel away to zoom in.
I would agree with you, but you're wrong.
As long as they give you the option to invert, I'm happy. Not all software has that option.
- x 1246
- x 2034
Fall back or fall forward.....Glenn Schroeder wrote: ↑Mon Aug 08, 2022 1:53 pm I agree, and Google maps has it backwards. Rolling the wheel toward you should zoom in. And that's not just because I'm prejudiced toward the default behavior with Solidworks. It seems counterintuitive to me to roll the scroll wheel away to zoom in.
SolidWorks feel more nature since it's how a 3d mouse work, push the part away (Roll up), and pull the part toward you (Roll down) But a lot of programs have seemed to standardize based on how Photoshop works so maybe 2D systems are to blame.
- x 380
- x 355
Actually every other system, Outlook, Word, File Explorer, etc. you roll towards you to zoom in. This a DEEP rabbit hole you could spend pages debating...jcapriotti wrote: ↑Mon Aug 08, 2022 4:27 pm Fall back or fall forward.....
- x 1654
- x 1489
And the fact that you can change scroll direction in Windows.
- x 1246
- x 2034
When users just put anything and everything in PDM.......no.....just no.
@bnemec Surely you never have this happen?
jcapriotti wrote: ↑Thu Oct 13, 2022 12:54 pm When users just put anything and everything in PDM.......no.....just no.
Actually, more of the opposite. People trying to avoid the vault for things that must go in. Things like CAD files for example.
You must have a much better vault implementation than we do.
Turn this on for your user's warnings. They won't be able to check anything in even if one little thing is outside the vault. This will force them to be all-in or not-in-at-all.
Yep, that's been checked since shortly after migration. There's just not much love of the vault here yet/still.
But as Jason pointed out there is some litter that shows up. We set up the "Add to Vault" filters pretty strict though.
- x 1246
- x 2034
In this case the files weren't checked in, still in the private state, however they are secretly uploaded on drag and drop. Also had another user with a folder called "Desktop" and an image file alluding to it being credit card information.
That might take the prize! Did they also share a pic of SS Card and DL?jcapriotti wrote: ↑Thu Oct 13, 2022 3:58 pm In this case the files weren't checked in, still in the private state, however they are secretly uploaded on drag and drop. Also had another user with a folder called "Desktop" and an image file alluding to it being credit card information.
I have not seen Documents or Downloads in the vault yet. So people here still trust the roaming profiles more than PDM.
I moved changed the location for Documents, Downloads etc. to local path; I have one of the shortest login/out waits.
- x 1654
- x 1489
Wait till someone drag and drop Vault into anther Vault folder.
Oh that was done several times by several people in the first 72 hrsFrederick_Law wrote: ↑Thu Oct 13, 2022 5:10 pm Wait till someone drag and drop Vault into anther Vault folder.
As well as obsoleted (changed state) on a top level files along with every single component in the extended BOM too.
- x 1654
- x 1489
Thanks, I'll copy that.
Corporate use PDM and SW, not changing that.
Locally we use Vault and IV. I need to make some changes.
- x 37
- x 95
You can turn that 'feature' off in MS Office applications, including Outlook.Glenn Schroeder wrote: ↑Thu May 19, 2022 8:23 am We use Outlook for email here. It's especially bad about that.
- x 1780
- x 2143
Would you mind explaining the process?Uncle_Hairball wrote: ↑Thu Feb 16, 2023 4:09 pm You can turn that 'feature' off in MS Office applications, including Outlook.
