Hello everyone,
I have written a macro that goes trough all components in the assembly and subassemblies and makes drawings from all the parts. However I have a problem that if the part is used more than once in a assembly (on the top level and/or in the subassembly) it makes a drawing for each instance of the part so there is as many drawings of the same part as there is instances of that part. Is there are way to skip identical instances? Maybe I'm missing something about GetComponents method?
Thank you
How to skip identical parts with GetComponents
- x 2
Re: How to skip identical parts with GetComponents
Create a List or Array. After you process a component, add its path to the list. Before you process a component, check to see if its path is in the list, and skip it if it is.
- Stefan Sterk
- x 73
- x 88
I start by making a list of unique components and then loop through it. as demonstrated by the code below
Option Explicit
Sub main()
Dim swUniqueCompList() As SldWorks.Component2
Dim swComp As SldWorks.Component2
Dim vComp As Variant
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then End
If swModel.GetType <> swDocASSEMBLY Then End
swUniqueCompList = GetUniqueCompList(swModel)
For Each vComp In swUniqueCompList
Set swComp = vComp
Debug.Print swComp.GetPathName
Next vComp
Function GetUniqueCompList(swModel As SldWorks.ModelDoc2) As SldWorks.Component2()
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Set swConf = swModel.GetActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
ReDim swUniqueCompList(0)
Set swUniqueCompList(0) = swRootComp
TraverseComponent swRootComp, swUniqueCompList
GetUniqueCompList = swUniqueCompList
End Function
Sub TraverseComponent(swComp As SldWorks.Component2, swUniqueCompList() As SldWorks.Component2)
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
For Each vChildComp In swComp.GetChildren
Set swChildComp = vChildComp
If Not IsCompInList(swUniqueCompList, swChildComp) Then
ReDim Preserve swUniqueCompList(UBound(swUniqueCompList) + 1)
Set swUniqueCompList(UBound(swUniqueCompList)) = swChildComp
End If
TraverseComponent swChildComp, swUniqueCompList
Next vChildComp
Function IsCompInList(swCompArr() As SldWorks.Component2, swComp As SldWorks.Component2) As Boolean
For Each vComp In swCompArr
If StrComp(vComp.GetPathName, swComp.GetPathName, vbTextCompare) = 0 Then
'If StrComp(vComp.ReferencedConfiguration, swComp.ReferencedConfiguration, vbTextCompare) = 0 Then
IsCompInList = True
Exit Function
'End If
End If
Next vComp
End Function
- x 2
Thank you, this worked flawlessly!Stefan Sterk wrote: ↑Sat May 21, 2022 4:25 pm I start by making a list of unique components and then loop through it. as demonstrated by the code below
Option Explicit Sub main() Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swUniqueCompList() As SldWorks.Component2 Dim swComp As SldWorks.Component2 Dim vComp As Variant Set swApp = Application.SldWorks Set swModel = swApp.ActiveDoc If swModel Is Nothing Then End If swModel.GetType <> swDocASSEMBLY Then End swUniqueCompList = GetUniqueCompList(swModel) For Each vComp In swUniqueCompList Set swComp = vComp Debug.Print swComp.GetPathName Next vComp End Sub Function GetUniqueCompList(swModel As SldWorks.ModelDoc2) As SldWorks.Component2() Dim swUniqueCompList() As SldWorks.Component2 Dim swConf As SldWorks.Configuration Dim swRootComp As SldWorks.Component2 Set swConf = swModel.GetActiveConfiguration Set swRootComp = swConf.GetRootComponent3(True) ReDim swUniqueCompList(0) Set swUniqueCompList(0) = swRootComp TraverseComponent swRootComp, swUniqueCompList GetUniqueCompList = swUniqueCompList End Function Sub TraverseComponent(swComp As SldWorks.Component2, swUniqueCompList() As SldWorks.Component2) Dim vChildComp As Variant Dim swChildComp As SldWorks.Component2 For Each vChildComp In swComp.GetChildren Set swChildComp = vChildComp If Not IsCompInList(swUniqueCompList, swChildComp) Then ReDim Preserve swUniqueCompList(UBound(swUniqueCompList) + 1) Set swUniqueCompList(UBound(swUniqueCompList)) = swChildComp End If TraverseComponent swChildComp, swUniqueCompList Next vChildComp End Sub Function IsCompInList(swCompArr() As SldWorks.Component2, swComp As SldWorks.Component2) As Boolean Dim vComp As Variant For Each vComp In swCompArr If StrComp(vComp.GetPathName, swComp.GetPathName, vbTextCompare) = 0 Then 'If StrComp(vComp.ReferencedConfiguration, swComp.ReferencedConfiguration, vbTextCompare) = 0 Then IsCompInList = True Exit Function 'End If End If Next vComp End Function
