Why is it so hard to get a formatting to stick in CREO table
I was asked by one of our user why the text style they applied to their table do NOT "stick".
What happen is that the user change the table style (eg: changing font size) for the entire table, then add a new row, the new row does not follow the new table style at all. The new row does not use or assume the style of every other row in the table.
Also, if the cell is blank when they change the table style, the style change will not apply to that blank cell at all
Apparently, this is the "behavior" for the table:
So basically it mean that if I need to change a table style and have the style "stick" to the table for all the new row that i create, i will need to create an entire NEW table.The Cell Formatting (for new Columns & Rows) is reverting back to the DTL settings of (default_font, text_height) that were active when the table was initially created. Whatever those values were set to when the table was created is what the new cells will be formatted as.
URRRGH
