SW PDM standard license
Discuss SolidWorks PDM
christian chu
x 39
Unread post by christian chu »
I have both SW and SWPDM server upgraded to 2022
Tried to login the Vault and got the err - see att. image
Any idea what it is
Thanks
by jcapriotti » Mon Oct 17, 2022 12:42 am
@christian chu Did you update the license manager server software to 2022?
x 2207
x 1860
Re: SW PDM standard license
Did you select the correct options on install? I think by default it install PDM pro. I remember having to make explicit choices to get PDM standard instead of Pro, but I can't provide any specifics without going through the install process.
christian chu
x 39
SPerman wrote: Sun Oct 16, 2022 4:11 pm Did you select the correct options on install? I think by default it install PDM pro. I remember having to make explicit choices to get PDM standard instead of Pro, but I can't provide any specifics without going through the install process.
Yes, I selected "standard" when installing it
x 1196
x 1984
AlexB
Answers: 27
x 265
x 440
Unread post by AlexB »
jcapriotti wrote: Mon Oct 17, 2022 12:42 am @christian chu Did you update the license manager server software to 2022?
Along the same theme, did you upgrade your SQL database with the upgrade tool? There's a fair bit of configuration that needs to be done to the database side in order to make it compatible with all the new features of a PDM upgrade. Although, I can't remember if it would let you connect to the vault if the versions don't match.
christian chu
x 39
AlexB wrote: Mon Oct 17, 2022 9:33 am Along the same theme, did you upgrade your SQL database with the upgrade tool? There's a fair bit of configuration that needs to be done to the database side in order to make it compatible with all the new features of a PDM upgrade. Although, I can't remember if it would let you connect to the vault if the versions don't match.
yes, I used this help link
https://support.hawkridgesys.com/hc/en- ... oc19890589
christian chu
x 39
I got error mesg while upgrading the license manager
x 1196
x 1984
@christian chu Did you move it to another server?
christian chu
x 39
jcapriotti wrote: Mon Oct 17, 2022 4:09 pm @christian chu Did you move it to another server?
no
