We have a workflow that trigger a revision up after a transition to a certain state.
same sample data made from our templates looking at the history I can see the revision label (A,B,C) if a normal user changes the file state no label if "admin" user does the same.
I looked at the workflow permissions and the admin is together with the normal users with the same permissions.
Recently I started to use often the admIn user and I noticed that kind of behavior...or am I looking at the wrong place?
SW2022sp5
SW2022 no revision label after state change (admin user Only)
Do you have more than one transition into the state? In other words, is there a chance that the admin user is getting the file into this state via some other transition that isn't setting the revision?
Go to full postRe: SW2022 no revision label after state change (admin user Only)
This is a valid concern, I will check tomorrow when I go back at the office. In theory no, but the previous admin created an hell of workflows and when the legacy wf blown up, a new and more complex one replaced it... I am not surprised anymore at this point
