What did this rookie do wrong?
RonaldNL
Unread post by RonaldNL »
What did I do wrong??
I must have clicked one or more settings
Answers: 25
x 818
x 998
Re: What did this rookie do wrong?
Expand your solid bodies folder and see if the body is hidden.
(FYI, if you press the "TAB" key while your mouse is over a body in a part, it hides the body. SHIFT + TAB brings it back)
There are other ways to unhide it, but that is the easiest.
RonaldNL
It looks like they should be visisble, nothing is hidden.
x 1225
x 2390
Just out of curiosity, what kind of video card are you using? What happens if you reboot your computer and try again?
JuTu
x 55
x 36
Unread post by JuTu »
DanPihlaja wrote: Wed Aug 02, 2023 4:39 pm (FYI, if you press the "TAB" key while your mouse is over a body in a part, it hides the body. SHIFT + TAB brings it back)
Fun fact about the SHIFT + TAB command. SolidWorks will unhide / show the first body or component that lies under the cursor depth wise from view direction. Like a beam it looks what is the closest hidden body and shows that.
Sincerely,
JuTu
__________________
Lentäjä on ulkona ja lukossa.
