how can i run two SW setup
i have model which is running simualtion with some fixed boundaries that can not change for motion analysis , how can i run same model where i can change boundaries and do Motion study
If you have a beefy computer, you can run 2 sessions of Solidworks at the same time (this will use 2 licenses). But my advice is to use a 2nd computer, because if it is running slow, then running a 2nd session will slow you down even more.
- x 818
- x 998
Re: how can i run two SW setup
I don't know about simulation, but I only have 1 license and I can run multiple instances of SW on my computer at the same time.
- x 818
- x 998
Really!? I assumed that it took another license. In fact, I remember a VAR telling me that exact thing. That 2 sessions of Solidworks on the same tube used 2 licenses..
Hrmm. Well then, looks like i was wrong. (I have been wrong before....this is generally what it looks like)
- x 1654
- x 1490
Don't think you should work on same model while sim is running.
The second session might lock the file and sim will crash.
I ran 4 different versions SW at the same time.
- x 1654
- x 1490
At one point, you can run 2 different versions or more on different computer with online license.
They broke it fast.
It could be different with network license.
They broke it fast.
To open the same model twice you'll need to rename it, not just a different folder, must be different name. AFAIK, Solidworks will not allow you to load the same file in two instances of sldworks.exe at the same time.
This is not the reason we do sim on copies of the "real" file, but that practice does help with the scenario you describe.
Edit: I was wrong about SW not allowing you to load the same file twice. It will not open the same file from the same location; it will ask if you want to open a "copy" of the file. It will allow you to load the same file name from a different directory, but I would avoid that as it will likely lead to problems.
- x 1
- x 31
With the stand alone desktop license you can open multiple sessions of Solidworks including different versions. As for loading the same part in 2 different sessions, you can do that but the first one you open will be the only one you're able to make any changes to since the others will open "READ ONLY". You could close the first part opened and then it should ask if you want to save it on the other session you're running
- Peter De Vlieger
- x 223
- x 105
Multiple sessions of solidworks on one computer?
Heck, I'm happy if even just one session runs without throwing a fit, freezing or crashing
By the by, running multiple session is indeed not impossible but it wil mean that the auto recovery functionality won't work AT ALL instead of only some of the time.
same scenario herePeter De Vlieger wrote: ↑Thu Aug 31, 2023 10:46 am Multiple sessions of solidworks on one computer?
