A Place to place our Improvement requests..?
I looked a little around here and could not find a thread or topic for us to post and discuss our enhancement requests.
I figure perhaps we could support each other a little and provide further support in the SWMP Enhancement request area.
Or, even the possibilty of that which we hope for may even be already possible, just unkown to us as to how..
I have a few in the system. Feel free to comment or vote on them. Or tell me why you hate them and think me a fool for asking for them..
Most of these are simple little user interface quirks that bug me.
https://r1132100503382-eu1-3dswym.3dexp ... M_2ukc9E4w "BOM Dialog Pin"
https://r1132100503382-eu1-3dswym.3dexp ... HMpd4OoRJg "Linear Pattern.SLDPRT."
https://r1132100503382-eu1-3dswym.3dexp ... 8jjG0lT2Gg "Section View Handle to Remain On-Screen at ALL Times."
https://r1132100503382-eu1-3dswym.3dexp ... yFYCToH1ow "Assign ALL Drawing views to single BOM/Cutlist."
https://r1132100503382-eu1-3dswym.3dexp ... Rcqw-UGBHA "Weldment Cutlist Item Select to FIND BODY"
https://r1132100503382-eu1-3dswym.3dexp ... e03zJhsNmw "Mirror.SLDPRT"
https://r1132100503382-eu1-3dswym.3dexp ... v-44XMmk7w "Feature Side Scroll Bar, Lock into Place."
https://r1132100503382-eu1-3dswym.3dexp ... 6SQ-bRhBbA "On Screen Floating Dialogs with Option to Pin into Place."
Re: A Place to place our Improvement requests..?
The secondary mirror face is very annoying. Almost have enough new muscle memory to click in the Features to Mirror window before selecting the features.
I can only assume several of you ran over there and hit like on most of these.
I appreciate it. Thank you.
Like your Linear Pattern.SLDPRT, there are a lot of places I would like to be able to set a different default.
Edit: To add a couple more..Damo wrote: ↑Sun Sep 24, 2023 7:32 pm I looked a little around here and could not find a thread or topic for us to post and discuss our enhancement requests.
https://r1132100503382-eu1-3dswym.3dexp ... MOZoImy7tw "Rescaled drawing view to remain in place."
https://r1132100503382-eu1-3dswym.3dexp ... -a9S6lf9Ig "Removal of the Unnecessary Cancel "X" in Feature Manager"
Thank you.
Just adding a couple more if anyone would find these helpful, please upvote..
https://r1132100503382-eu1-3dswym.3dexp ... i0vp4kyomg "Reorder Display States"
https://r1132100503382-eu1-3dswym.3dexp ... XRCe2G3f-g "Save all Button should actually Save ALL.."
I hope these can help others too..
- x 48
- x 401
Something of an idea dump;
Ability to apply face colours at the assembly level
Ability to Move Hole Tags to Detail Views
Ability to Specify Drawing View Location on Sheet
Able to Adjust Overlapping Balloons in a Stack
Add Dimensions to Favorites
Add Option to Pin the Fillet Feature Manager
Add option to use Construction Geometry while mirroring sketch entities
Add PEM SI Ultrasonic Heat Staking insert holes to Hole Wizard
Add Sketch Colour to RMB Menu at Assembly Level
Add Table of Datum Locations
- x 48
- x 401
Add to Balloon Stack from BOM / FMT
Allow General Tables in Drawing Sheet Format
Allow Magnetic Lines to have Balloons from Multiple Views
Allow Setting of Detail View Preferences as Document Properties
Apply Jogs to Corners
Automatic Sequential Note Numbering Across Pages
Breakout Counterbores to Avoid ZTG
Broaden Plane Autosize Functionality
Choose Open Models During Replace Model in Drawings
Circular Profile Sweep – Remember Last Used Diameter
- x 48
- x 401
Cosmetic Knurls
Decal Property Manager to remember last used location
Dedicated BOM Sheets
Define Chamfer by Angle and Diameter
Delete Component Group from Tree
Drag Folders in to Sub-Assemblies
Drawings – Ability to Attach a Balloon to Multiple Mag Lines
Drawings – Auto Hide Balloon Quantity if 1X
Explode View – Select All Items in Pattern
Fillet all Concave Corners Connected to Start Loop
- x 48
- x 401
Group Hole Callout Instance Counts
GUI for Hole Wizard Callout File
Hole Table – Able to “Renumber All Tags” while “Combine Same Tags” is Active
Hole Table – Assign Tags to Same Layer as Table
Hole Table – Fully Adjust Datum Leader Position
Hole Wizard – Reverse Offset from Surface
Indicate if Folder Contains Under Defined
Insert Model Items, Chamfers to Respect Doc Properties
Installation Manager – Show Progress in Taskbar
Isolate Folders
Isolate Folders
- x 48
- x 401
Iteratively Purge Unused Features
Left Hand Cosmetic Thread Support
Library Features in Assemblies
Link All Sketch Chamfer Dimensions
Link Feature Description to Model Parameter
Measure Distance between Cosmetic Threads
Multi-Column Notes
Name Fillet / Chamfer Feature Based on Size
Near Side Counterbore in Hole Wizard
Nest Curves in Feature Manager
Multi-Column Notes
- x 48
- x 401
Pack and Go “No to All” Option
Permanently Discard "Document has been Modified or Converted in this Session" Message
Permanently Discard "Save as Copy and Open" Dialog Box
Permanently Discard “Upgrading Cosmetic Threads” Warning Message
Provide a set of tools for creating geometry primatives in the 3D sketch
Recognise Adjusting Centre Marks with Undo
Re-implement the ability to edit appearance while model Section View is enabled
Retain if an Item is “Excluded from BOM” when Patterning
Selection Filter for Area Hatch / Fill
Show PEM Minimum Distance to Edge
- x 48
- x 401
Thanks for sharing, Dave! Voting now.
- x 48
- x 401
- CarrieIves
- x 388
- x 144
Add an option to set a folder as the default destination for Copy Tree and Pack and Go
https://r1132100503382-eu1-3dswym.3dexp ... pcmISq9d-g
Add warnings to Pack and Go when PDM is in use
https://r1132100503382-eu1-3dswym.3dexp ... l2cLwsBPIg
- x 5
- x 57
Open and check out, and save and check in buttons...
https://r1132100503382-eu1-3dswym.3dexp ... G3EJKJkg0Q
"BOM Dialog Pin"
"Mirror.SLDPRT"
It seems the benevolent folks at Dassault are asking us again for our TopTen requests.
But rather than wading thru their own clunky and slow "Enhancements Request" forum, they are requiring us to resubmit our requests.
And so, I have.
Anyone who would appreciate these small improvements please feel free to click all those like buttons.
Speaking of "small UI annoyances". I'd very much like the F*****G opening dialog box to stop damn well resizing and moving the selection when i select a part file or drawing. FFS that is infuriating and i can't believe its still in their from when they first changed that dialog years ago to introduce one good thing (3 quick filter buttons) and take away two others (the aforementioned and also its new ability to "forget" the current working path all the damn time) whilst introducing even more infuriating annoyances (selecting the drop down filter to SWFiles never sticks, selecting the 3 quick filters includes random crap that shouldn't be there is isnt there with the drop down selection. Why are will still filter SolidEdge file formats as though they are SW formats that have never bene since like SW96. the list goes on).
Yes, i'm dead sic kof this infuriating simple crap from "professional", expensive software that now make it infuriating to even log into a webpage tot eh point i dont want to go near it.
