I have searched the KB and the closest Q&A I found on the topic says that it is not possible to batch destroy a vault view.
I am not so convinced, If I kill the epdm.exe task and console delete the vault view, then overwrite the registry I should be able to reroute to my new servers? Am I missing something? Yes, it would be not supported etc...
I have PDM and SW installed with an admin image so everybody has the same setup regarding PDM.
I am not interested in PDM client uninstall.
I have already made a CVS file to install a new vault view via batch.
Q&A Is it possible to completely uninstall the SOLIDWORKS® PDM client and remove the local view via a command line script?
Portfolio / Domain: SOLIDWORKS Desktop / GOVERNANCE
Product: SOLIDWORKS PDM Professional CAD Editor Network
Platform: On Premise
Question
Answer
There is no automatic method to remove a vault view. To manually perform the complete uninstall:
1. Right-click view and remove it.
2. Uninstall Enterprise from add/remove programs
3. Delete the SOLIDWORKS® PDM registry keys.
To perform the clean uninstall via command line script , use a *.bat file and perform the steps in the following order:
1. Uninstall Enterprise using MSIEXEC /x as described in knowledge base solution QA00000108838
2. Delete the two Enterprise registry keys:
HKEY_CURRENT_USER\Software\SolidWorks\Applications\PDMWorks Enterprise
HKEY_LOCAL_MACHINE\SOFTWARE\SolidWorks\Applications\PDMWorks Enterprise
3. Delete the (now orphaned) local view folder.
Keep in mind that this will completely remove SOLIDWORKS PDM, so any checked out files to that view will still show as checked out in the database. Please ensure that users check in all files before attempting this operation.
For additional help with completely removing SOLIDWORKS PDM, please contact either your Local SOLIDWORKS Reseller or SOLIDWORKS Technical Support.
