SOLIDWORKS pet peeves
x 2308
x 1947
Re: SOLIDWORKS pet peeves
When working on a part, inside of an assembly, Solidworks ALWAYS picks an external reference. For example, if drawing a circle on the face of the part I am editing, it could reference the origin of the part I'm working on, or it could reference the origin of the assembly. Picking the origin of the part would mean no external reference, but SW will pick the origin of the assembly, requiring me to open the part and correct those external references.
I know it is possible to turn off the creation of external references. I don't want that, I use it regularly. I just want, if given the option, for SW to pick the local reference over the external one.
Answers: 26
x 821
x 1006
SPerman wrote: Tue Sep 24, 2024 1:40 pm When working on a part, inside of an assembly, Solidworks ALWAYS picks an external reference. For example, if drawing a circle on the face of the part I am editing, it could reference the origin of the part I'm working on, or it could reference the origin of the assembly. Picking the origin of the part would mean no external reference, but SW will pick the origin of the assembly, requiring me to open the part and correct those external references.
Yes, I have taken to selecting from the tree instead of selecting from the graphics window when things are close together/overlapping.
x 2574
x 1422
We don't keep external refs very long as they destroy file management, but we tried using weld beads in assembly models and I'm guessing you haven't or you would say it ALWAYS selects weld beads, even when viewport is set to not display them!
The selection concept in Solidworks is backwards and fundamentally flawed with decades of workaround and band-aids instead of just fixing it.
x 2308
x 1947
bnemec wrote: Thu Sep 26, 2024 9:59 am We don't keep external refs very long as they destroy file management, but we tried using weld beads in assembly models and I'm guessing you haven't or you would say it ALWAYS selects weld beads, even when viewport is set to not display them!
I always break external references after created. I frequently use the assembly to locate mounting holes, and then go into the part, delete those relations and constrain it locally.
nevillew
x 30
x 11
Unread post by nevillew »
My pet peeve at the moment is not being able to kill the incessant "updating bounding boxes" on opening larger assemblies. (SW 2020).
This seems to slow down document opening to a crawl.
There doesn't seem to be any macros for removing this behaviour.
Answers: 26
x 821
x 1006
This is a GIF file. Click on me.
grumph o[ hhhh
EDIT:
OK, I figured it out.
In order to make that shape, I had used the Arc Slot function at the part level and used it cut that shape out.
When I replaced it with normal geometry, everything is fine.
So looks like another feature that I am never going to use again in Solidworks. hhhh
DennisD
x 1054
x 1483
Unread post by DennisD »
DanPihlaja wrote: Wed Nov 13, 2024 8:52 am This is a GIF file. Click on me.
grumph o[ hhhh
EDIT:
Well that makes about as much sense as the 3DSWAMP! >>>
- - -Randy Pausch
dave.laban
Answers: 5
x 48
x 409
Unread post by dave.laban »
I wonder how tall my sheet of paper will need to be to show that many rows on a revision table. Certainly a curious default for it to arrive at!
HercalloY
x 53
x 39
Unread post by HercalloY »
dave.laban wrote: Thu Dec 19, 2024 5:16 am I wonder how tall my sheet of paper will need to be to show that many rows on a revision table. Certainly a curious default for it to arrive at!
Must be the conversion factor to go from Metric to 3DEXPERIENCE (i.e. nothing makes sense when you go 3DEXPERIENCE). ;)
x 2308
x 1947
Solidworks just signed me up to receive all of their spam emails. Even after "unsubscribe from all" they keep coming.
x 2574
x 1422
SPerman wrote: Mon Dec 30, 2024 8:11 am Solidworks just signed my up to receive all of their spam emails. Even after "unsubscribe from all" they keep coming.
This is rather unremarkable. I set up spam filters for most of DSS/SW stuff a while ago. Unsubscribing is useless, it may be that they are required to remove an email address from the list(s) upon request; but I'm guessing there's nothing stopping them from adding it back on in a short amount of time. Just mark it read and can it, don't waste time with trying to stop marketing.
DLZ_SWX_User
x 244
x 38
Unread post by DLZ_SWX_User »
bnemec wrote: Mon Dec 30, 2024 9:57 am This is rather unremarkable. I set up spam filters for most of DSS/SW stuff a while ago.
Filters is a great friend in many waysI :idea: UU
