PDM, Is there a better place to Destroy the Deleted files? Sort by file type?
The Vault Properties dialog window is fine for General and Permissions maybe, but the Deleted Items tab needs more room but the window size is locked.
I have not set up to automatically destroy deleted files, there's been too many times I needed to go back and see what had happened, when by whom. But it would be very nice to sort by file type so I can clear out all the sim results that people let go into the vault as well as step files and other junk like that. I don't know how to add the "file type" column to the Deleted Items view in the Vault Properties window. Is there a better place to do this from?
- x 1253
- x 2045
Re: PDM, Is there a better place to Destroy the Deleted files? Sort by file type?
They could certainly improve it. The only suggestion I can think of is to restore the files..... Move them into a delete sub folder to sort on them there.
Fyi, Shift delete bypasses the recycle bin and destroys the files. Not sure if you can make use of that in some way.
I assume that's from vault view UI? Hopefully it's regulated by user/group permissions?jcapriotti wrote: ↑Sun Oct 23, 2022 3:50 pm They could certainly improve it. The only suggestion I can think of is to restore the files..... Move them into a delete sub folder to sort on them there.
- x 1253
- x 2045
Its standard Windows function for bypassing the recycle bin.....in the vault you must have Destroy permission though.
There is an enhancement SPR for adding the ability to sort the Deleted Items. SPR 1099065
That would be so nice to have right now.
I think I figured out why the archive server filled up "all of a sudden" Someone must have run some automated PDF creator tool and it dumped them in the vault along side the slddrw files. The they realized what it did and deleted them. I realized to sort by date is about the cleanest way to find them.
I don't understand all that goes on in the back ground, but I have learned to see a little. It seems that all these deleted files are still in the documents table just have the deleted field set to 1. If I could add that to a search, deleted = 1, and have ability to destroy from there, that would be awesome, all the columns I need are right there.
I cannot think of a need for any other interface, just use what's already there?
- x 1253
- x 2045
Searching deleted files would be nice and seems like an easy enhancement. Delete just toggles that flag in the Documents table, Destroy removes the record from the table. There are other tables affected so you can't just toggle the deleted state or remove the record without consequences.bnemec wrote: ↑Wed Oct 26, 2022 1:00 pm I don't understand all that goes on in the back ground, but I have learned to see a little. It seems that all these deleted files are still in the documents table just have the deleted field set to 1. If I could add that to a search, deleted = 1, and have ability to destroy from there, that would be awesome, all the columns I need are right there.
Yes, the tables are strictly read only for me. I created a separate SQL security account for when I query the DB directly in code. That user is can only perform select statements.jcapriotti wrote: ↑Wed Oct 26, 2022 1:43 pm Searching deleted files would be nice and seems like an easy enhancement. Delete just toggles that flag in the Documents table, Destroy removes the record from the table. There are other tables affected so you can't just toggle the deleted state or remove the record without consequences.
Just voted for that ER with note explaining why adding function to the PDM Search Tool would be great. Hopefully someone at PDM dev will see it and consider. Even if it's not possible, a reply explaining that would be nice.
The report generator can help you out as well. Here's a report that lists all deleted files, sorted by file extension.
@[ListDeleted]
§Name [All deleted files sorted by file type]
§Company [CADForum]
§Description
[This query will list all deleted files, sorted by file extension.]
§Version [1.1]
§Arguments
§Sql
select Docs.Filename as 'File Name',Projects.Path as Location,Hist.Time as 'Deleted On',Hist.ProjectID,Users.FullName as 'Deleted By',
lower(right(Docs.FileName, charindex('.', reverse(Docs.Filename) + '.') - 1)) as 'File Type'
from dbo.Documents as Docs
inner join dbo.HistoryDelete as Hist on docs.DocumentID = Hist.DocumentID
inner join dbo.Users as Users on Hist.UserID = Users.UserID
inner join dbo.Projects as Projects on Hist.ProjectID = Projects.ProjectID
where Docs.Deleted = 1 order by 'File Type'
The report generator occupies the space between plain vanilla EPDM search and remoting in to the server and using SQL Management Studio.
Agreed that is a great tool that I do not use often enough. I still need to order them in the tiny properties dialog view to be able to destroy them.JSculley wrote: ↑Wed Oct 26, 2022 2:42 pm The report generator can help you out as well. Here's a report that lists all deleted files, sorted by file extension.
Gives you something like this:Code: Select all
@[ListDeleted] §Name [All deleted files sorted by file type] §Company [CADForum] §Description [This query will list all deleted files, sorted by file extension.] §Version [1.1] §Arguments [ ] §Sql [ select Docs.Filename as 'File Name',Projects.Path as Location,Hist.Time as 'Deleted On',Hist.ProjectID,Users.FullName as 'Deleted By', lower(right(Docs.FileName, charindex('.', reverse(Docs.Filename) + '.') - 1)) as 'File Type' from dbo.Documents as Docs inner join dbo.HistoryDelete as Hist on docs.DocumentID = Hist.DocumentID inner join dbo.Users as Users on Hist.UserID = Users.UserID inner join dbo.Projects as Projects on Hist.ProjectID = Projects.ProjectID where Docs.Deleted = 1 order by 'File Type' ]
SPR 915332
Sir, thank you for this script. I was able to load it, but since we have so many deleted files, it's taking forever. I'm as dumb as a box of hammers with this code. It would be nice if it could prompt me for a specific workflow, either if I can select it or enter the workflow name. Would you be able to assist with this? This would make it workable for me to be able to identify all deleted files for a particular workflow.JSculley wrote: ↑Wed Oct 26, 2022 2:42 pm The report generator can help you out as well. Here's a report that lists all deleted files, sorted by file extension.
