Extruded Cut won't cut?
Ballfreak10
x 26
x 3
Unread post by Ballfreak10 »
Hi all,
In the attached file, I'm trying to create a simple cut (through all) using the sketch "SKETCH Middle Cut". However, when I try, SW gives me the error message below. Surely I must be doing something wrong...?
All help is appreciated :)!
Thanks,
Interior_Back.SLDPRT
(64.28 KiB) Downloaded 277 times
x 2434
x 2076
Re: Extruded Cut won't cut?
Wrong direction buddy :) Look at the image, the arrow points to the left, and your sketch is on that face.
x 1225
x 2390
Ballfreak10 wrote: Wed Apr 14, 2021 2:17 pm Hi all,
Thanks,
Sloppy sketching. Sketch entities should touch end to end.
Answers: 25
x 818
x 998
Real quick (without downloading your file) I am guessing that you need to uncheck "thin feature".
Or, if you really are looking for a "thin feature" that you make sure that your thickness is less than the smallest radius for the wall thickness direction that you are going.
x 1225
x 2390
Nope. @AlexLachance The sketch is on the top face, and cuts in the right direction.
@dpihlaja It is an open sketch, but not intentionally. It actually has multiple open profiles and also overlapping profiles. Seriously sloppy sketching.
x 1225
x 2390
Dragging some sketch points to where they should intersect fixes the problem.
Interior_Backmatt.SLDPRT
(96.25 KiB) Downloaded 206 times
x 1780
x 2143
@matt pointed out one problem. Here's another one.
Clean those areas up (on both sides), and it will work.
Answers: 25
x 818
x 998
matt wrote: Wed Apr 14, 2021 2:29 pm Nope. @AlexLachance The sketch is on the top face, and cuts in the right direction.
OK, you are right....however, it doesn't really make sense that "thin feature" was checked on this one anyway..... so....in addition to what @matt and @Glenn Schroeder said, also uncheck thin feature because it doesn't seem to make sense in this case.
x 1225
x 2390
dpihlaja wrote: Wed Apr 14, 2021 2:53 pm
If you fix the other problems, the thin feature option won't be checked automatically. SW just sees open profiles and automatically sets thin feature.
x 2434
x 2076
You're right, after relooking at the screenshot the vertical construction line connects to the top face and not the alternate. I must be getting tired
Answers: 25
x 818
x 998
matt wrote: Wed Apr 14, 2021 3:05 pm
Ahh, I didn't think of that. Thanks @matt !!
x 2434
x 2076
matt wrote: Wed Apr 14, 2021 2:22 pm Sloppy sketching. Sketch entities should touch end to end.
@Ballfreak10 This is your issue
(quoting because he PM'ed me ;) )
