"Sweep Operation Failed To Complete"?
- x 26
- x 3
Hi all,
In the attached file, I'm trying to use "SKETCH Swept_Ac" & "SKETCH Swept_Path" to create a swept feature. When I try to do so, SW gives me the error message in the title. Could this be because the end of the new feature would touch the pre-existing "Base" feature, or otherwise?
All help is appreciated !
Thanks in advance,
Thanks in advance,
- Rod.SLDPRT
- (63.51 KiB) Downloaded 287 times
Re: "Sweep Operation Failed To Complete"?
Sweeps aren't allowed to run into themselves. That's called "self intersecting geometry". When you put the sweep path in the middle of the profile and then put a sharp sketch transition in there, the sweep runs into itself. Think about what you are trying to create, and then how to follow the rules to do that.
I moved the path from the middle down to the bottom of the profile. This allows it to complete without self intersecting.
- x 26
- x 3
I got the same error upon moving the start of the sketch from the center to the bottom edge.matt wrote: ↑Tue Jun 29, 2021 12:22 pm Sweeps aren't allowed to run into themselves. That's called "self intersecting geometry". When you put the sweep path in the middle of the profile and then put a sharp sketch transition in there, the sweep runs into itself. Think about what you are trying to create, and then how to follow the rules to do that.
- x 26
- x 3
As Matt had mentioned, changing the path will make it work as it clear up the self intersecting geometry
In the example above, the path was shifted such that the sweep path is piercing the lower line instead of the center of the profile One thing to keep in mind is that this changes may be different from your original design intent
- x 26
- x 3
I feel like what I have here is essentially the same thing, though? And yet I'm getting the same error.Zhen-Wei Tee wrote: ↑Fri Jul 02, 2021 1:12 pm As Matt had mentioned, changing the path will make it work as it clear up the self intersecting geometry
Did your sweep path "intersect" the sweep profile plane?Ballfreak10 wrote: ↑Sat Jul 03, 2021 11:29 am I feel like what I have here is essentially the same thing, though? And yet I'm getting the same error.
Do you mind to share again this file so that we can take a look?
- x 26
- x 3
Yes, the profile sketch is highlighted in the attached screenshot - they do intersect.Zhen-Wei Tee wrote: ↑Sat Jul 03, 2021 12:02 pm Did your sweep path "intersect" the sweep profile plane?
Could you reupload the file so that we can take a look?Ballfreak10 wrote: ↑Sat Jul 03, 2021 12:09 pm Yes, the profile sketch is highlighted in the attached screenshot - they do intersect.
From the screenshot shown it should have no issue creating the sweep
- x 26
- x 3
I can't find an option to edit my original post, so I'll attach it here.Zhen-Wei Tee wrote: ↑Sat Jul 03, 2021 12:15 pm Could you reupload the file so that we can take a look?
- Rod.SLDPRT
- (111.23 KiB) Downloaded 208 times
I took a look at your file and noticed that your arc radius is smaller than your sweep profile height. This will create a self intersecting geometryBallfreak10 wrote: ↑Sat Jul 03, 2021 12:30 pm I can't find an option to edit my original post, so I'll attach it here.
Can you change the arc dimension to at least 0.25inch?
- x 26
- x 3
I’ll try that next time I’m at my computer, thanks. But why would those dimensions cause self-intersecting geometry?Zhen-Wei Tee wrote: ↑Sat Jul 03, 2021 1:02 pm I took a look at your file and noticed that your arc radius is smaller than your sweep profile height. This will create a self intersecting geometry
By default, your sweep profile will follow the profile (Unless you change it in your sweep setting)Ballfreak10 wrote: ↑Sat Jul 03, 2021 1:06 pm I’ll try that next time I’m at my computer, thanks. But why would those dimensions cause self-intersecting geometry?
Hence if your profile is larger than your arc which is convex / concave upward**, they will self-intersect...
R .230 (original sketch)/b] R .250
**This will be a different situation if your arc is concave downward as the profile will not intersect Edit: Added image to better illustrate R.250
- x 26
- x 3
Zhen-Wei Tee wrote: ↑Sat Jul 03, 2021 1:15 pm By default, your sweep profile will follow the profile (Unless you change it in your sweep setting)
R .250
So I was able to get the Sweep operation to complete until I added one small horizontal line at the bottom-left of the path sketch (In the file attached here)...and now I'm back to getting the same error!
- Rod.SLDPRT
- (111.7 KiB) Downloaded 186 times
Again, this is due to the self intersecting profile....Ballfreak10 wrote: ↑Sun Jul 04, 2021 11:26 am So I was able to get the Sweep operation to complete until I added one small horizontal line at the bottom-left of the path sketch (In the file attached here)...and now I'm back to getting the same error!
When working with sweeping non-tangential convex path, you need to be aware of how your profile is being sweep.
See the image below, the horizontal profile is intersecting with the convex curve profile
There are a few workaround and that depends on your design intent
Option 1: Creating a horizontal line that is tangent to the convex curve
The convex curve will change (either shrink vertically or grow horizontally)
Notice that how the profile on horizontal line no longer intersect the profile from the curve because the line is tangent to the curve
Option 2: Split the sweep into 2 feature (You will need either 2 sketch or using selection manager)
For the first sweep, sweep until the curve end point (red sketch)
For the second sweep, sweep using the face and the horizontal line (green sketch)
Depending on the design intent, you might need an additional extrude to get the horizontal end face
However, this option will cause the sweep on the horizontal line to have different profile than the original sweep profile (note the 0.25 and 0.24 dimension).
This is because in the second sweep, the face is forced to follow the horizontal line, hence the sweep profile is projected, causing the dimension to change
Option 3: Use Keep Normal Constant for your Profile orientation option
This will force the profile normal to be kept constant
But that note that this will produce a really "bad" geometry at the curve area
Each option will produce different result.
I believe Option 1 is the correct way for this case if you want to have a consistent sweep profile
