Be Active - please...
Several announcements for new users.
DennisD
x 1037
x 1474
Re: Be Active - or else...
Unread post by DennisD »
matt wrote: Tue Jun 29, 2021 9:30 am Don't worry. I'm only worried about accounts that have never posted anything clearly relevant. You're definitely OK.
Well, that requires a definition of "relevant" now doesn't it.
It is Monday. . .
- - -Randy Pausch
Emra
x 3
x 6
Unread post by Emra »
Hi all!
Solidworks user and accidental company CAD/PDM admin here. I'm a long-time lurker of the old SW forums, and am very excited to see this new site since the old one died. Also I am definitely a real person and not a bot; please don't kick me?
x 2256
x 1902
x 815
x 993
SPerman wrote: Wed Aug 04, 2021 7:52 amimage.png
This is offensive to AI.
x 1219
x 2387
Emra wrote: Tue Aug 03, 2021 11:27 pm Hi all!
Don't worry, I only kick out people who spell Solidworks with all caps. :D
x 2489
x 1899
That's exactly what a bot would say...@matt, ya may want to kick @Emra out...
x 1219
x 2387
mattpeneguy wrote: Wed Aug 04, 2021 10:09 am That's exactly what a bot would say...@matt, ya may want to kick @Emra out...
It's a good thing I didn't make you a moderator.
Tom G
x 989
x 466
Unread post by Tom G »
x 1777
x 2142
matt wrote: Wed Aug 04, 2021 10:21 am It's a good thing I didn't make you a moderator.
You just now figured that out?
dgrippin
Unread post by dgrippin »
Roger that,
I'm an Electrical Systems Manuf. Engineer for a microwave antenna/satellite antenna positioning systems manufacturer in NC. I use both Draftsight and Solidworks daily. Still trying to get the best performance out of SW, even after almost 1 year with it. They hooked me up with a powerful PC, but I still get hang ups pretty frequently. Where do I start looking?
x 1777
x 2142
dgrippin wrote: Wed Aug 04, 2021 1:46 pm Roger that,
That's a pretty general question. You might have better luck posting a specific question (unless I'm completely misunderstanding something).
x 1219
x 2387
One year isn't a lot. There's a pile of stuff in the software, and after almost 30, I still don't know everything (and I've forgotten half of what I did know). Coming here is a good start. Ask questions that confuse you. Read Mastering Solidworks, but seriously, there's a lot of good stuff in there, not just the stuff from the SW training.
x 2256
x 1902
Hopefully this doesn't come across as snarky. As far as Solidworks is concerned, lower your expectations. It is slow on the best hardware. It crashes / hangs fairly regularly. A lot of this can be avoided by following better practices, but even then, it has issues.
Jaylin Hochstetler
x 380
x 355
SPerman wrote: Thu Aug 05, 2021 7:19 am Hopefully this doesn't come across as snarky. As far as Solidworks is concerned, lower your expectations. It is slow on the best hardware. It crashes / hangs fairly regularly. A lot of this can be avoided by following better practices, but even then, it has issues.
Customer: "It's slow and doesn't work right."
VAR: "Oh, your not doing it right you have to use a different workflow. It's as simple as remodeling everything."
Customer: o[ grumph :x
Edit: This why they don't specify a best workflow.
x 2256
x 1902
I was told that in order to make pack and go work properly, we had to completely redo our folder structure. (To one that is not possible in our organization.)
1. Pack and go works best when no more than 3 folders separate the top level assembly from the furthest away component. This 3 level folder separation must be done vertically in the directory tree. Similar to the example below
.....a. Top level
.........i. Sub assy 1
.........ii. Sub assy 2
............1. Sub assy 2.1
2. Pack and go usually has difficulty with success if it has to navigate out of the top level folder into another main directory or over a network to gather all parts
(ignore all of the periods. That is the only way I could get the indentation to layout properly on the fourm.)
x 1777
x 2142
SPerman wrote: Thu Aug 05, 2021 8:25 am I was told that in order to make pack and go work properly, we had to completely redo our folder structure. (To one that is not possible in our organization.)
I'm surprised to see that. Pack and Go works just fine for me, and I often have project specific files on one network drive and my library parts and sub-assemblies on another one.
x 1219
x 2387
Re: Be Active - please...
Ok, the "or else" was a bit much, so I changed that. Unless you're using the Breeze theme, in which case you may never see the change.
jwelihin
x 6
Unread post by jwelihin »
Hi there,
Looking for places to learn about how to work with CAD and not finding answers on Reddit. Thought this would be great - so far, learning a ton. As we speak, I'm designing my new shed in AutoCAD :P
J
Cadmonkeychris
x 5
x 10
Unread post by Cadmonkeychris »
I was wondering where the familiar names of CAD past had disappeared to following the demise of the SW boards (enough has been written about that).
22 years of SWx including 16 as a freelancer, now considering something new (to be posted in the Agnostic board)
x 2419
x 2061
Cadmonkeychris wrote: Wed Mar 16, 2022 9:05 pm I was wondering where the familiar names of CAD past had disappeared to following the demise of the SW boards (enough has been written about that).
A few of them just didn't have the same feeling on here as they had on the previous SW Boards, unfortunately. But, for the most part the community is still thriving.
