physical simulation of a marble run
Hansjoerg
x 71
x 61
Unread post by Hansjoerg »
Hello to all,
to get a little bit more into physical motion simulation, I was looking for a simple "project".
Well, what is fun for the little ones to play, is good for the big ones to practice.
https://www.youtube.com/watch?v=-yMGzGU9Ccs
But it is not as easy as it looks.
In my first attempt, the marble simply gets stuck, even though the hole in the starting block is large enough. (Marble run with Funnel.SLDASM)
Since I couldn't get the problem with the stuck marble under control, I built a start ramp (marble run with ramp.sldasm). But again I am not completely happy with the simulation. I have the impression that the marble loses disproportionately much speed already in the lower area of the ramp.
If you compare the simulation with the video, you can see that the marbles are much more lively in the same launch situation.
Am I missing any parameters here, or why does my result deviate so far from reality, or does it not work at all?
If you want to play a bit more, here is a simulator https://www.cuboro-webkit.ch/
marble run with ramp.SLDASM
(1.03 MiB) Downloaded 213 times
marble run with Funnel.SLDASM
(950.95 KiB) Downloaded 165 times
mike miller
x 1070
x 1231
Re: physical simulation of a marble run
Unread post by mike miller »
That's pretty cool! Unfortunately I'm not much help but I'm going to keep an eye on this because it's fascinating.
This is another fascinating project. :lol: Backspin is important to your basketball free throw simulation study
MJuric
x 875
Unread post by MJuric »
Hansjoerg wrote: Mon Oct 18, 2021 4:43 pm Hello to all,
How is the marbel getting stuck. I didn't download what you've already done but dia really quick similar simulation and it seemed to work fine. Attached a quick video of it.
All I did was do a Motion analysis with a sphere and a swept path and it worked fine. I typically use "Use precise contact" and bump up the accuracy until parts aren't going thru each other. Beware though the higher the accuracy the longer it takes to calculate.
Assem1.avi
(418.5 KiB) Downloaded 148 times
Hansjoerg
x 71
x 61
hey,
I've done a few additional tests.
I reduced the diameter of the marble. With the smaller marble, it is possible to get past the point where the marble with the original dimensions gets stuck.
But a little further on, the smaller marble also gets stuck. It looks like it is hanging on a silk thread from an sky hook.
I made a video of the simulation with the original dimension and the reduced dimension.
marble run with funnel-smaller marbel.mp4
(842.49 KiB) Downloaded 160 times
marble run with funnel1.mp4
(790.67 KiB) Downloaded 131 times
zxys001
Answers: 5
x 2327
x 1005
Unread post by zxys001 »
..yeah, imho, something is not quite right with the assembly or the path curves?... so, to simplify this, I'd create another part or profiles to create your combined path and use that for the cutting for the others parts or use it as your main body for the simulation.. and it seems to work fine..(image)
