Free rotate a part in an assembly
x 1214
x 2365
Say you want to pre-assemble a part. Kind of pre-position it so it fits the right way. Is there a way other than steering wheel to do that? Can you drag the rmb or shift-alt-drag the mmb. You can position a part in the Parts Library preview window. Just something I can't find. Thanks to anyone who has the answer!
Jaylin Hochstetler
x 380
x 355
Re: Free rotate a part in an assembly
matt wrote: Fri Nov 05, 2021 5:28 pm Say you want to pre-assemble a part. Kind of pre-position it so it fits the right way. Is there a way other than steering wheel to do that? Can you drag the rmb or shift-alt-drag the mmb. You can position a part in the Parts Library preview window. Just something I can't find. Thanks to anyone who has the answer!
You could use the Drag Component. Attached is a video I made using "Drag Component" and the steering wheel.
SE Move Component in Assy.wmv
(7.16 MiB) Downloaded 102 times
x 1214
x 2365
Jaylin Hochstetler wrote: Mon Nov 08, 2021 7:38 am You could use the Drag Component. Attached is a video I made using "Drag Component" and the steering wheel.
So SE doesn't have an equivalent? You can rotate the part in the preview window, but not in the actual assembly?
x 1231
matt wrote: Mon Nov 08, 2021 9:46 am So SE doesn't have an equivalent? You can rotate the part in the preview window, but not in the actual assembly?
Yes, I know it does as a hotkey under Drag Component. I'm trying hard to think of it right now....maybe @TusharSuradkar or @Imics13 would know offhand.
x 1214
x 2365
Well, it's kind of tricky, but you can set up the 3D Connexion driver to rotate individual parts in the assembly. Kind of a drag if you don't have that. Maybe SE users get used to not having something quick and easy for positioning parts that are already in the assembly.
Jaylin Hochstetler
x 380
x 355
matt wrote: Mon Nov 08, 2021 10:44 am Well, it's kind of tricky, but you can set up the 3D Connexion driver to rotate individual parts in the assembly. Kind of a drag if you don't have that. Maybe SE users get used to not having something quick and easy for positioning parts that are already in the assembly.
I agree, I like that feature in SW.
But what I like about the Drag Component is the ability to rotate on an axis, for instance see the video attached.
SE Move Tube in Assy.wmv
(4.61 MiB) Downloaded 99 times
Imics13
x 41
x 100
Unread post by Imics13 »
Hi Guys,
Sorry for late answer, but I'm here. Yes you can do it but you have to use assemble command with Flash fit relationship.
Here is a short video:
I tried to give another answer for using live preview instead of static picture. It helps to "preorientate" the model.
BR,
BR,
