How to Use Sketch Arrays Effectively
x 220
Unread post by Dwight »
All
I found what for me is a new approach to using sketch arrays and now I find them to be very effective and a time saver. If you are interested, I recorded a demo video - see this YouTube link - https://youtu.be/e17Xli50dFg.
x 220
Re: How to Use Sketch Arrays Effectively
Thanks. I am rolling this out for our engineering group. I'd like to hear about what I missed.
berg_lauritz
Answers: 6
x 439
x 233
Unread post by berg_lauritz »
Dang! I love it. I need to use this!
x 815
x 993
Dwight wrote: Thu Jan 13, 2022 9:29 am All
What is the title of the Youtube video? (for some reason the short link won't work and gets blocked by Barracuda).
Shaun
x 30
x 6
Unread post by Shaun »
Title is "DEMO SKETCH ARRAYS 17 minutes"
x 220
Dan
I selected to make it available only with a link. Sorry that does not work for you. I tried to change that setting but didn't see a way to do that. Apparently, though, I can invite you specifically to view it, just need your email address, I think. I can give it a shot.
x 220
Okay, I figured out how to make the video public, but it still doesn't come up in a search.
x 815
x 993
Dwight wrote: Thu Jan 13, 2022 11:22 am Dan
Hang on....what I didn't think of was to forward it to my personal email and viewing on my phone. LOL
The many varied paths that technology allow you.
I swear that the largest thing that limits us technologically is security....
x 220
All
This "floppy" sketch array method keeps working better and better for me. I use it all the time for sketch arrays, and now I find that a "floppy" sketch circular pattern works great, too. This afternoon I used it to make a copy of some lines turned around 180 degrees. The trick is to not use the complicated relations created by the tool. Instead I filled out as few parameters as I could (just the count and the angle), hit the green check, then deleted all the construction lines that came in with the pattern. That left me with the copied lines at the angle I wanted, and I could drag them anywhere I wanted. I added some relations and got it locked down. Perfect!
The "floppy" sketch circular pattern is shown here. It fixed in place with the colinear relation and the 120 dimension.
I suppose I need to add this to the video.
berg_lauritz
Answers: 6
x 439
x 233
Dwight wrote: Mon May 09, 2022 4:33 pm All
Wow... this looks super clean. I need to try this....
HDS
x 37
x 28
Unread post by HDS »
Better in a second video but defiantly an interesting trick.
I have seen the advice several times to not use Sketch Patterns but you have show how they can be a very useful tool.
I have been frustrated before that I could not pattern features from the center. This is a good work around.
I would like to know how performance compares between a Sketch Pattern like this and a future pattern. For files with huge feature counts in the pattern this can be a real issue.
Answers: 32
x 1236
x 2029
HDS wrote: Wed May 11, 2022 8:55 am Better in a second video but defiantly an interesting trick.
I've likely given that advice, although there are cases I've used it. Dwight's example is good especially considering the way the hole wizard functions with sketch points and you can build it parametrically and control it. Outside of the Hole Wizard, I tend to prefer feature patterns since you can reference them from an assembly pattern. But it's great to have another tool in the shed as you never know what kind of geometry you'll come across.
TTevolve
x 87
x 168
Unread post by TTevolve »
question.... is there a good reason to use a sketch array vs. using a feature array?
Most of the time I prefer to use the hole wizard for holes anyways since the call outs are better on drawings.
x 220
New link:
x 220
TTevovle
Sketch arrays often work well in a Hole Wizard feature.
