Solidworks - rope mechanism for a finger
Hi everyone! I got stuck somewhere in our prosthetic robotic hand project for disabled people which I am doing by using Solidworks software. The finger moves as I want, but I have to add a "simple rope mechanism" as an animation. I have also drawn the necessary channels for the finger to pass the rope, but I am having a problem in drawing the rope, passing it through the channels, and casting it into animation. Unfortunately, there is no such video about animation on Youtube and other platforms. Any help is appreciated!
part_3.SLDPRT
- part3
- (206 KiB) Downloaded 141 times
part_2.SLDPRT
- part2
- (204.3 KiB) Downloaded 156 times
part_1.SLDPRT
- part1
- (389.21 KiB) Downloaded 112 times
Index_assemb.SLDASM
- assembly
- (323.05 KiB) Downloaded 114 times
Re: Solidworks - rope mechanism for a finger
Cool project!seizerr wrote: ↑Tue Mar 08, 2022 2:44 pm Hi everyone! I got stuck somewhere in our prosthetic robotic hand project for disabled people which I am doing by using Solidworks software. The finger moves as I want, but I have to add a "simple rope mechanism" as an animation. I have also drawn the necessary channels for the finger to pass the rope, but I am having a problem in drawing the rope, passing it through the channels, and casting it into animation. Unfortunately, there is no such video about animation on Youtube and other platforms. Any help is appreciated!
There is this pulley example that might be helpful:
You could also export the STL files and use Blender to make the animation, will be much better than SW, but you will have some learning curve to go through.
Btw, you could use the Gear Mate to make them move together:
Here you go, paste them in a different folder because I didn't rename your files.
Also this one is with Splines, first I tried with Arc. I think splines looks more realistic... you might get better results after some adjustments.
- I had to make the sweeps inside each part because was the only way to snap the cable relations trough it.
- Depending on the position you will blow up the sketch and have to manually fix it.
- You need to adjust the pipe length in part 2 for a better movement.
part_3.SLDPRT
- (215.49 KiB) Downloaded 151 times
part_2.SLDPRT
- (223.9 KiB) Downloaded 136 times
part_1.SLDPRT
- (436.81 KiB) Downloaded 140 times
Index_assemb.SLDASM
- (513.36 KiB) Downloaded 127 times
cable.SLDPRT
- (186.87 KiB) Downloaded 127 times
Thank you so much!
