Where do you get your MACRO ICONS
loeb
x 40
x 10
Unread post by loeb »
I've developed a bunch of VBA macros that I depend on regularly. I have them in a custom toolbar, but they all have the same default SolidWorks icon.
1) Have you found a 'library' of useful icons that work well for this purpose?
2) Do you have a utility that makes it quick and easy to make your own custom icons?
Thank You
HerrTick
x 32
x 307
Re: Where do you get your MACRO ICONS
Unread post by HerrTick »
Make your own in MS Paint
loeb
x 40
x 10
I did find this tip at https://www.javelin-tech.com/blog/2020/ ... olidworks/
Extra:
As you can see above, the Macro button has a generic icon image. If you want to apply a unique image for the Macro button, click “Choose Image” under “Appearance” in Step7. SOLIDWORKS provides bitmap images to use for custom buttons which can be found in install_dir\data\user macro icons.
(Eg. C:\Program Files\SOLIDWORKS 2020\SOLIDWORKS\data\user macro icons)
You can also create your own bitmap images that are 16×16 pixels, 256 colours, and with a white background.
In my case, the path is C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\data\user macro icons\
It only contains 14 icons.
x 600
Personally i "created" mine in PPT and then save as png then convert to bmp...
Most of the time i will get the "base icon" (eg: icon for Save, Dimension, Note, etc) from solidworks help page. After that change the icon colour using PPT recolour function so that it will not get confuse with the original icon. In some cases, i will add some additional symbol (eg: arrow for export, x for clear, etc)
x 2434
x 2076
I find images on google
Ömür Tokman
x 995
x 347
Unread post by Ömür Tokman »
I don't use icons for macros because vba icons look awful. Explanation is enough for me. Macro icons made with C# are nice.
x 2282
x 1921
I make my own with paint.
x 818
x 998
SPerman wrote: Wed Aug 17, 2022 2:17 pm I make my own with paint.
I came here to say this.
