Automatically add display data marks to default cfg
Posted: Fri Mar 25, 2022 10:57 am
by berg_lauritz
Is there a possibility to add a display data mark automatically to the first & only configuration?
Currently if we make new configurations (i.e. flat pattern) it won't automatically have a display data mark for the 1st configuration.
Adding new configurations will automatically add a display data mark though.
Am I doing something wrong? This feels like a bug.
Re: Automatically add display data marks to default cfg
Posted: Fri Mar 25, 2022 1:09 pm
Yeah....not really a bug I guess but definitely not ideal. Best you can do is create two configurations for your template or have a sheet metal template with the flat configuration already in place.
Maybe you could submit as a bug. If you have two configs and add the display mark to both, then delete one so there is only one config, then add a second config back, the first no longer has the display mark.
Posted: Fri Mar 25, 2022 1:38 pm
by Hansjoerg
I've noticed this illogical behavior as well, don't understand the point of this function either.
With the function Mark for rebuild when saving it behaves exactly the same.
I have also tried to add the markers for the standard configuration already in the template. But if there is only one configuration, the function is not available.
Next, I tried to trick the system by creating a second configuration, setting the markers for the display status and for the rebuild, and then deleting the additional configuration. Unfortunately, the markers disappear in the remaining configuration again....
I have to check if it is possible to add the markers to a single configuration with a macro and then save it as a template.
But all in all, this is again a huge effort to find a workaround to make an insufficiently thought-out function usable.
My frustration level is steadily rising........
Posted: Mon Mar 28, 2022 9:07 am
by berg_lauritz
Thank you @jcapriotti & @Hansjoerg for re-creating the same thing that I did & confirming that I have not gone mad.
I did the same & was very frustrated because I am not willing to create two configurations for parts that do not need more than one. I guess I'll have to live with it for now.
Posted: Mon Mar 28, 2022 1:07 pm
berg_lauritz wrote: ↑Mon Mar 28, 2022 9:07 am
Just an FYI, we are going away from having the Rebuild Markup as a default for all configurations and instead instructing users to do a Rebuild All Configurations before the final save. Reason for us is we have some automation and we are experiencing very long save times when saving an assembly where it decides to save some of the part/sub-assy files and has to rebuild a lot of configurations on every save. This is also related to Windchill so you may not have the same issue.
Posted: Mon Apr 25, 2022 12:38 pm
by gupta9665
How about using a macro to set the display data mark?
Posted: Wed Jun 08, 2022 1:48 pm
by berg_lauritz
gupta9665 wrote: ↑Mon Apr 25, 2022 12:38 pm
Didn't you post a macro like that somewhere else? Can I link that to this post?
Posted: Fri Jun 10, 2022 1:21 pm
by gupta9665
berg_lauritz wrote: ↑Wed Jun 08, 2022 1:48 pm
Try the following codes (the codes will add display data mark to each config in active model file)
Option Explicit
Option Explicit
Sub main()
Dim swConf As SldWorks.Configuration
Dim swConfMgr As SldWorks.ConfigurationManager
Dim configNameArr As Variant
Dim configName As Variant
Set swModel = swApp.ActiveDoc
If Not swModel Is Nothing Then
If Not swModel.GetType = 3 Then
Set swConfMgr = swModel.ConfigurationManager
configNameArr = swModel.GetConfigurationNames
'Set Large Design Review marks for all configurations to true
For Each configName In configNameArr
Set swConf = swModel.GetConfigurationByName(configName)
swConf.LargeDesignReviewMark = True
Next
swModel.ForceRebuild3 (False)
End If
End If
Posted: Mon Sep 30, 2024 10:26 am
by woollyhayles
Hi there. This macro is perfect for what I need. Do you know how to modify it so that it can be used during a transition in Solidworks PDM?
Thanks
gupta9665 wrote: ↑Fri Jun 10, 2022 1:21 pm
Option Explicit
Option Explicit
Sub main()
Next
End If
End If
Posted: Mon Sep 30, 2024 1:02 pm
by AlexB
woollyhayles wrote: ↑Mon Sep 30, 2024 10:26 am
You would have to put that scripted code into a Task (using the SWTaskAddIn & PDM Professional). Then during your transition, you can add an action that triggers the Task you've created.
Posted: Tue Oct 01, 2024 2:01 am
by woollyhayles
I've got the task created in the admin tool in PDM but I'm unsure on how to modify it to get it to work as it fails every time during the transition. I'm guessing it needs some additional code but I'm unsure on what or how to add it. Thanks
Posted: Tue Oct 01, 2024 9:27 am
by DanPihlaja
Probably the easiest solution is to create a dummy configuration in your part template (and/or assembly template).
Then apply the "rebuild on save" mark to both, then re-save your template.
Anyone who wants to can utilize the dummy config as needed. Or simply add a new config.
- image.png (7.61 KiB) Viewed 2030 times
Posted: Wed Oct 02, 2024 10:45 am
by AlexB
woollyhayles wrote: ↑Tue Oct 01, 2024 2:01 am
Can you post the code that you're using?
Posted: Wed Oct 02, 2024 5:15 pm
by mp3-250
What is the error?
Beware You need to checkout the file to modify the content.
