import a 3d dwg to part
Library for macros
doobes
x 12
x 84
Unread post by doobes »
Hey there,
I'm fairly VBA centric, but this one has me flummoxed.
I've got a butt load of old 3D dwg's that I got from KraftMaid years ago, which are cabinet models.
Way back yonder, I used SketchUp to design a kitchen, but I'm doing a new kitchen and want to use Swx.
I can't for the life of me figure out how to import a dwg into a part instead of a drawing or a sketch via the API.
I've got a nice macro for importing folders of step files and saving to SolidWork parts that I was leveraging for this, but SolidWorks is insistent on importing the dwg's either into drawings or sketches.
I can do this manually. I've tried recording a macro doing it and that's useless as running it again imports the dwg as a drawing.
Any thoughts?
chris
x 2207
x 1860
Re: import a 3d dwg to part
While in the part, select a plane for the sketch to be placed upon, and select "insert", then "DXF/DWG"
doobes
x 12
x 84
Not what I'm trying to do.
You can open a dxf/dwg from the dialog as a part by selecting that option.
Can't figure out how to do that programmatically.
chris
x 2207
x 1860
Does this help at all? I know it isn't importing it the way you want, but it's a start. It's probably a matter of figuring out how to set the arguments.
https://help.solidworks.com/2017/englis ... ple_VB.htm
https://help.solidworks.com/2017/englis ... file4.html
https://help.solidworks.com/2017/englis ... gData.html
Looking through those links, it doesn't look like what you want is an option.
Answers: 27
x 265
x 440
SPerman wrote: Thu Jul 14, 2022 6:38 pm Does this help at all? I know it isn't importing it the way you want, but it's a start. It's probably a matter of figuring out how to set the arguments.
I was going to suggest the same thing, but I tried it out and it puts all the entities into a sketch for any argument that applies to a part file. I'm not sure of a way to get it to convert the dxf into curve features.
doobes
x 12
x 84
Okay,
I've dug through the API doc's with limited/no success.
Here's what I'm trying to automate:
1) Open a dwg file:
2) Select the "import to new part as: 3D curves or model"
3) Choose the correct settings:
4) and Voila!, part:
If I do a macro record of this, which then looks like this:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
boolstatus = swApp.LoadFile2("V:\Engineering\Mechanical\Models\KraftMaid\Office\CAD_DKD362D.dwg", "0 0")
Set Part = swApp.ActiveDoc
This is the end result:
Definitely not what I'm looking for.
I've played around with this code:
Dim filename As String
Dim longerrors As Long
Dim retVal As Boolean
Dim importData As SldWorks.ImportDxfDwgData
filename = "V:\Engineering\Mechanical\Models\KraftMaid\Base Cabinets\CAD_BPPSFCC3627.dwg"
Set importData = swApp.GetImportFileData(filename)
importData.ImportMethod("") = SwConst.swImportModelItemsFromEntireModel
Dim newDoc As SldWorks.ModelDoc2
Set newDoc = swApp.LoadFile4(filename, "r", importData, longerrors)
The problem is there are about eleventy-seven options for the import method and the import data values.
I've tried a bunch of them with no success. Some do nothing at all, some open the file as a drawing.
Any ideas?
Thanks,
chris
doobes
x 12
x 84
Wow, just wow. Just for fun, I went over to the SolidWorks user forum to see if I could find anything there.
That's friggen useless. No topic segregation so everything just get jammed together. The chances of finding anything are remote, and I suspect any message asking for assistance is going to get lost in the noise.
So, I filed a support request. That's 2 in 2 days! I'm on a roll....
chris
x 2353
x 2008
@josh might be of help. He's like THE reference in these type of things :P
Do you have an example model we could use to try it on our end..? Maybe your issue is version dependant..?
doobes
x 12
x 84
Can't attach a dwg, so it's here: https://www.dubea.com/CAD_DKD362D.dwg
chris
doobes
x 12
x 84
Mod's, would you please move this discussion to "API"?
I put this in the wrong place.
Thanks in advance
chris
