Hi Everybody,
after changing coordinate system I need to extract new mass properties.
In particular, I need to get principal intertia axes: I thought the function PrincipalAxesOfIntertia (IMass2) did exactly this.
I found the data extracted are not the same as those I found on mass properties window (I have same absolute values but different signs on x and y array and same data on z array).
Does anyone know why? Does exist another function to do this task?
Thanks in advance,
Mattia
PRINCIPAL AXES OF INERTIA
- x 1
Hi @Mattia Bianchi, is there any chance you can send this model so I can troubleshoot? I have a lot of problems with IMassProperty2 (not as many as I had with IMassProperty), but I have found a few workarounds so want to give it a run on your model). The workarounds are applied in xCAD: https://github.com/xarial/xcad/blob/mas ... roperty.cs
Go to full postRe: PRINCIPAL AXES OF INERTIA
If using IMassProperty2, you can set the coordinate system and then recalculate the mass properties.
https://help.solidworks.com/2021/englis ... ystem.html
- x 1
That's what I did: I created a new coordinate system, set it and finally recalculated mass properties.
Then I extract all mass properties and I can see the values are the same as those I can read into mass properties window.
Only Principal Axes of Inertia make an exception: they have all the absolute value that I expected but different signs (in particulare opposite signs in x-y arrays and same sign in z array).
Thanks,
Artem
Artem
