McMaster Cleaning Macro
I thought I remembered someone on here mentioning a macro they used to clean all of the junk out of McMaster Carr part files. If someone could point me to that macro, or even that thread, I would appreciate it.
- x 790
- x 944
Re: McMaster Cleaning Macro
I don't use a macro. I just save the part as a parasolid and then overwrite the original Solidworks file. Works like a charm.
I was hoping for one of these:
- x 1614
- x 1454
You're assuming McMaster model are consistent.
Download STEP?I don't use a macro. I just save the part as a parasolid and then overwrite the original Solidworks file. Works like a charm.
That works for most items. I like having the history tree on fasteners so that I can suppress the threads.
The biggest problem with McMaster Carr models is the visual properties are maxed out.
I have a macro for reducing image quality.
Setting these two sliders in the middle will cut the file size to 30% of what it is initially. Suppressing the helix will cut that in half again.I have a macro for reducing image quality.
Exactly! Also, delete all equations in the file.MattW wrote: ↑Thu Jan 26, 2023 5:06 pm The biggest problem with McMaster Carr models is the visual properties are maxed out.
Share one sample file and what changes you would need and then I will try to create one
Don't download models from MMC or vendors. Start with a parent model and copy it to make all similar part types. Then they can be easily swapped out in the where used. Importing steps or SW models from everywhere will never likely not have same geometry IDs.
For example, in our data set a 1/4-20 x 1.00 SHCS and a 3/8-16 x 1.50 HHCS should have same face IDs for the cylinder that represents threads as well as the face under the head should have same ID on each. Anything else makes for a lot of lost time in product maint.
- x 790
- x 944
Basically, you want to get rid of unneeded design table data, update graphics slider to something lower, possibly suppress a helix (if applicable), and possibly get rid of equation data.
- x 1614
- x 1454
Randomly picked a few.
- 90201A443_Extreme-Strength Grade 9 Steel Hex Head Screw.SLDPRT
- (639.4 KiB) Downloaded 40 times
- 91268A618_High-Strength Grade 8 Steel Hex Head Screw.SLDPRT
- (708.74 KiB) Downloaded 77 times
- 91813A160_Mil. Spec. Low-Strength Steel Hex Nut.SLDPRT
- (285.32 KiB) Downloaded 91 times
- 90685A110_High-Strength Steel Hex Nut.SLDPRT
- (409.45 KiB) Downloaded 65 times
Can you add finished version of these files as well i.e. after making the required changes.
- x 1614
- x 1454
Sorry, I don't have SW. I just get them from McMaster Carr.
I'll let other clean that up.
Or upload what they use.
After thinking about it over the weekend, what I want is to strip away everything that isn't directly related to the geometry (custom properties, equations, backgrounds, scenes, decals, etc.) Given that request, I think the easiest thing to do is as Fred suggested earlier, import a format that doesn't come with all of that overhead. For fasteners, I will have to decide what is the best way to eliminate the threads. (For those, maybe I will import the sw file, suppress the helix, then save as a step and re-import.)
- zxys001
- x 2294
- x 988
or, saveas a parasolid (native, fast and no translation)SPerman wrote: ↑Mon Jan 30, 2023 3:56 pm After thinking about it over the weekend, what I want is to strip away everything that isn't directly related to the geometry (custom properties, equations, backgrounds, scenes, decals, etc.) Given that request, I think the easiest thing to do is as Fred suggested earlier, import a format that doesn't come with all of that overhead. For fasteners, I will have to decide what is the best way to eliminate the threads. (For those, maybe I will import the sw file, suppress the helix, then save as a step and re-import.)
