Sweep Cut Curved surface Will do single but not multiple
Posted: Thu Jan 26, 2023 10:44 pm
by OldOZNoob
Hello,
Trying to multiple sweep cuts across a face like below. Allows a single cut but the face needs about 90 repeated going left to right on the concave surface.
Error message comes back
- image.png (25.33 KiB) Viewed 2063 times
But it will do a single?
Lost as I performed the exact same task on a convex surface yesterday with no issues. Also it will let me enter each cut individually if i put it on a new sketch each time, but im not doing that.
Please help.
Ol Oz
Re: Sweep Cut Curved surface Will do single but not multiple
Posted: Thu Jan 26, 2023 11:52 pm
by zxys001
Hi OldOZNoob, can you share the file?
Posted: Thu Jan 26, 2023 11:57 pm
by OldOZNoob
Hi Zx,
Hope this works !
Never shared a file
You can see the first one. Just trying to repeat that across the entire concave.
Posted: Fri Jan 27, 2023 8:37 am
by AlexB
I took a look at this just to be sure because I figured this is caused by zero-thickness-geometry.
A sweep-cut is a boolean operation so it subtracts the "solid" you're making with your sweep from the existing solid. I manually performed that operation by creating your sweep as a solid and patterning it across the length. When I use Combine -> Subtract, I get this error.
My advice is to do one of the following:
1) Get rid of this point in your sweep profile pattern.
It needs to be a single enclosed profile (in most cases)
2) Your sweep needs to be made up of many single sweep operations (not really a good practice)
Posted: Fri Jan 27, 2023 9:19 am
by TTevolve
Make it a revolve cut and pattern it. I had to add extra reference geometry because you didn't start off the standard planes as the center and nothing was locked down. But it should work better.
I would not use a sweep unless I had to, usually when the profile needs to change path in all 3 directions. Patterns will regenerate faster.
Posted: Fri Jan 27, 2023 6:03 pm
by OldOZNoob
Thank you very much TT Evolve that's a great help.
@Alex B I'll give that a try also.
Thanks for posting Zx, these chaps have sorted it.
Cheers everyone!!
Old Oz
Posted: Sun Mar 17, 2024 10:24 pm
by FTUMCH
Cool handle oldoz
GDay from sunny Perth
