Is there a way to highlights parts from a BOM table?
Posted: Sun Feb 05, 2023 8:49 pm
by Mike Gera
Say you have a BOM table and don't know what item #9 is. There is no Description property data for the item and the part number isn't making sense.
Is there a way to highlight all "item #9's" in a BOM-linked drawing view?
Note: I do know how to fly out to the left in the BOM table and see the item thumbnail. That alone doesn't always crack the case, however.
Thanks for any help.
Re: Is there a way to highlights parts from a BOM table?
Posted: Sun Feb 05, 2023 11:22 pm
by Alin
Mike Gera wrote: Sun Feb 05, 2023 8:49 pm Say you have a BOM table and don't know what item #9 is. There is no Description property data for the item and the part number isn't making sense.
Change the colour of item#9 in the BOM.
https://help.solidworks.com/2023/englis ... at_dlg.htm
Maybe use the same color for the corresponding balloon.
Posted: Mon Feb 06, 2023 2:20 am
by gupta9665
Clicking on the row should highlight the components in the view and the feature tree (if expanded)
Posted: Mon Feb 06, 2023 3:11 am
by acmall
Another option is if the part number column in the BOM is the actual SolidWorks file name right clicking on it should give you the option to open the file.
Posted: Mon Feb 06, 2023 9:01 am
by Mike Gera
gupta9665 wrote: Mon Feb 06, 2023 2:20 am Clicking on the row should highlight the components in the view and the feature tree (if expanded)
Thanks, that worked. I never knew of that feature!
For some reason, though, it only works for parts and not assemblies. Does that sound accurate?
Posted: Mon Feb 06, 2023 9:02 am
by Mike Gera
acmall wrote: Mon Feb 06, 2023 3:11 am Another option is if the part number column in the BOM is the actual SolidWorks file name right clicking on it should give you the option to open the file.
Yes, but in a big assembly, sometimes that's not enough to figure out where the part is used.
Posted: Mon Feb 06, 2023 9:19 am
Mike Gera wrote: Mon Feb 06, 2023 9:01 am Thanks, that worked. I never knew of that feature!
Seems to work for assemblies on my end. I'm on 2019 SP5.
Posted: Mon Feb 06, 2023 9:36 am
by TTevolve
I prefer to just use the Open part command from the right click menu on the BOM part/assembly and edit the customized fields as need in the part.
Posted: Sat Feb 11, 2023 9:51 am
by Mike Gera
AlexLachance wrote: Mon Feb 06, 2023 9:19 am Seems to work for assemblies on my end. I'm on 2019 SP5.
For some reason, mine only works with parts. Strange.
