Hi,
I am updating a old SW drawing, I went in a replaced the sheet properties with the company's latest and greatest.
Now here is where I can't figure out is how to add a revision anchor, the sheet had Template instead of Sheet format and when I right click there is no anchor options:
Now on the bill of materials if I right click, I get a anchor option:
On the revision table I again don't have the option:
I know this should be simple but how do I add the latest and greatest to this drawing short of replacing it?
Regards,
Jim
Adding Anchors to a Old SW drawing
Right click in the drawing sheet, select 'Edit Sheet Format'.
Right click a point in the sheet format and the 'Set as anchor' item should be on the pop-up menu. From there you can specify which type of table should be anchored there.
Go to full postRight click a point in the sheet format and the 'Set as anchor' item should be on the pop-up menu. From there you can specify which type of table should be anchored there.
Re: Adding Anchors to a Old SW drawing
Hi again,
I tired it and as you can see no anchor option:
I would have thought this would be an easy one to fix or that the anchors would have imported with the new sheet properties.
Regards,
Jim
Regards,
Jim
- x 1648
- x 1477
Hi,
Guess my eyes are going quicker than I thought, joys of old age.
Regards,
Jim
Regards,
Jim
- x 1648
- x 1477
You need a drink.
