Weldment - Invalid Path?
Posted: Thu Apr 27, 2023 1:28 pm
by m2shell
This problem just appeared out of nowhere.
When I go to insert a weldment feature, I get an error "Invalid Path".
My Weldment Profile path is set correctly in File Locations
But it looks like it is trying to access a location called "\\\C:\Program Files\SolidWorks Corp\...(etc)"
Why would it be looking in such a strange location?
I even checked the file location in registry, but it looks fine.
Off subscription so can't try VAR.
Already tried a repair. Should i just re-install?
SW2022sp5
Re: Weldment - Invalid Path?
Posted: Thu Apr 27, 2023 1:39 pm
I know you looked in the registry but try a Registry reset:
https://www.javelin-tech.com/blog/2019/ ... -registry/
Posted: Thu Apr 27, 2023 1:56 pm
by m2shell
Good idea.
I tried, and I was able to insert Weldment without an error.
THEN
I restored my customizations via the "Restore Settings" command. And the error re-appeared.
I then Re-Restored to an older setting backup and the problem went away.
So it looks like I have some corruption in the most recent customization backup.... wow
Posted: Thu Apr 27, 2023 1:58 pm
Don't restore everything.
Uncheck and only restore one category.
See which one cause problem.
Posted: Thu Apr 27, 2023 2:05 pm
by m2shell
Frederick_Law wrote: ↑Thu Apr 27, 2023 1:58 pm
Yep. It was the System Options settings that were causing the problem.
Thanks!
Posted: Thu Apr 27, 2023 2:16 pm
Now, compare the setting files and see what's different.
Notepad++ can do that with Plugin:
https://notepad-plus-plus.org/downloads/
Posted: Fri Apr 28, 2023 4:47 am
by mp3-250
solidworks has the bad habit to export sldreg as an invalid registry file to begin with... I had a very bad experience deploying system options with a sldreg. solidworks FIXES the sldreg after some consistency check but exports garbage like SOME paths without escaping the slashes resulting in invalid paths...
Posted: Fri Apr 28, 2023 3:40 pm
by m2shell
mp3-250 wrote: ↑Fri Apr 28, 2023 4:47 am
I haven't yet done the comparison with Notepad++ that
@Frederick_Law recommended. But I think it all started last week when I was creating some new macro buttons and experienced some "irregularities" during the process...
Now that I think of It has SW yet fixed the behavior that you can't delete a macro in the "Keyboard Shortcut" menu once you've put it there? I still have some bespoke macros defined there from 6-7 years ago that have no context anymore.
Posted: Fri Apr 28, 2023 4:24 pm
Do not export on first start of SW after install.
SW won't write to registry until it close.
That export will be mostly empty.
Posted: Fri Apr 28, 2023 5:00 pm
by m2shell
Frederick_Law wrote: ↑Fri Apr 28, 2023 4:24 pm
Wow. That's a great bit of info. Thanks
@Frederick_Law
Posted: Sat Apr 29, 2023 7:25 pm
by mp3-250
m2shell wrote: ↑Fri Apr 28, 2023 5:00 pm
Wow. That's a great bit of info. Thanks @Frederick_Law
This is a nice finding and I will keep it in mind.thank you for sharing
@Frederick_Law
Unfortuanatelly I had a bad experience well after the first startup, in fact I imported and exported again the SLDREG file "to clean it up" with SW checks and be sure I was using a proper registry file before deploying to our clients.
Solidworks fails to write a proper REG4 format and implodes if you apply that registry file outside Solidworks.
I was wrong.
see
viewtopic.php?t=2586
Imagine a *working* administrative tool that allow you to setup *all* options inside SW, PDM, EDRAWINGS, SIMULATION inside a coherent envroinment...
