We recently purchased a CNC press and I'd like to make sure that the flat panel generated by Solidworks matches the bend allowances generated by our press, not by Solidworks. Can anyone help me find the right parameters to adjust?
On the press we can manually enter a finished flange length and see the negative offset calculation to account for the die bend radius, deformation and everything else. My question is how exactly to translate that value into a custom bend allowance or bend reduction or whatever the appropriate parameter is.
Configuring Solidworks Bending Parameters to Match Press
Designated Pot-Stirrer
Re: Configuring Solidworks Bending Parameters to Match Press
You'll probably have to run some test sheets through the press to verify your bend table parameters.
Produce a sample, measure the sample, update bend table, verify SW matches real world result.
What company did you purchase the press break from? We are looking at Amanda and Trump ones and both have bends table that can be downloaded into Solidworks.
Been there. Done that. We figured out how to explain and measure our K-factors with great results.jmongi wrote: ↑Wed Jun 14, 2023 9:45 am We recently purchased a CNC press and I'd like to make sure that the flat panel generated by Solidworks matches the bend allowances generated by our press, not by Solidworks. Can anyone help me find the right parameters to adjust?
You should be verifying what the CNC is computing as well as what SWX is computing. The only way to do that is by measuring coupons before and after bending. See files here:
https://cadforum.net/viewtopic.php?p=66 ... ctor#p6667
- - -Randy Pausch
- - -Randy Pausch
- x 1614
- x 1454
Don't try to "translate" press setting to SW.
Not yet.
Not until you compared model to bend part and got them to match.
Not yet.
