Design Table auto created only some of the configurations
Posted: Wed Jul 19, 2023 3:51 pm
by jmongi
So, I'm trying my hand at some design configurations. I created a design table, all the data is in there fine (this is for a compressed split lock washer). All of the # labels got created as a configuration (i.e. #2 size, #8 size, etc).
However, the fractional sizes did not get created (1/4, 5/16, 3/4, etc). Any thoughts? Is this a special character issue? I'm surprised "#" worked where "/" isn't.
Re: Design Table auto created only some of the configurations
Posted: Wed Jul 19, 2023 4:05 pm
by jmongi
Well, that was the answer. Changed "/" and they came in.
But...for some reason the whole numbers "1" and "2" got removed from the list? That one has me stumped.
To clarify, I had a list of sizes from 1/4 to 2. While the rogue character prevented SW from autogenerating configurations named that way, they still existed in the table itself. But, when I rebuilt all configurations, somehow the 1 and the 2 rows were just nuked from the table. I now realize (from recopying and pasting the original data) that it has done this before too. Any idea what is going on?
Posted: Wed Jul 19, 2023 4:15 pm
jmongi wrote: ↑Wed Jul 19, 2023 4:05 pm
Maybe your configs are set in alphabetical order and that causes it to misplace it in comparison to your design table?
1 would be before 1/16 I believe in that case and 2 would be before 3/16"
I numbered them in decimal because I was running into something similar if I remember correctly.
Posted: Wed Jul 19, 2023 4:33 pm
Random inexplicable problems in Solidworks? That's hard to believe.
Posted: Wed Jul 19, 2023 5:23 pm
by XHawkeye
Can't use '/' as a configuration name.
- Capture180.JPG (19.65 KiB) Viewed 961 times
In our system, 95% of the time configuration name = our P/N so the '/' isn't missed. But when I've used fractions in configuration names, like Alex I've used decimals and then use the faction in the configuration description.
Posted: Thu Jul 20, 2023 8:42 am
by TTevolve
I purposely add a part number field to my design tables and don't use the configuration name as the part number for this reason. When you do BOM you can add a column for any property.
