I Want to Add "Description" Column to the State Change Columns
Posted: Fri Aug 04, 2023 11:19 am
When I want to change the state of a file, it would be helpful if, after the p/n column, there was the description column.
I see in the "Columns" section of the PDM admin program you can add another column set, but not modify the existing default column set. If I create a new column set, lets say we call it, "State Change 2", how can I re-direct PDM to use the new column set?
I'm using PDM SW2021.
Thank you for any help you may give me...
