Determine Configuration Name for each BOM QTY Column?
loeb
x 39
x 10
Unread post by loeb »
I have a BOM table for multiple configurations of an assembly. I would like to be able to get the name of the configuration for each QTY column. Is there a way to traverse the QTY columns and get the config name/number?
x 438
x 459
Re: Determine Configuration Name for each BOM QTY Column?
Select the option "Show configuration in BOM header" and you will see the configuration names instead of QTY
And if you want to add QTY. as well, then select "Show custom text in BOM header" and add QTY.
