I'm trying to set up our task host according to these instructions, so that it processes the tasks again after a reboot, without anyone having to start the PDM first.
I have proceeded as described in the instructions, but the processing of the tasks only works as long as I am logged on to the task host, after a reboot, or even when I log off, all tasks remain in the queue.
How is the Task Host set up for you?
PDM Task host without user login
Re: PDM Task host without user login
Ours is set up to automatically log in to windows after re-start. PDM is set up to automatically log in to our PDM Task user account when the windows user is logged in. So, when the system is restarted, it gets back into PDM without me having to do anything and begins running tasks again.
We have a little difficulty with that. The settings in the registry for the automatic user login are always reset. Probably MS Intunes has its fingers in the pie.
@AlexB: Without a logged in user it didn't work for you either?
this is bad! Is there a possibility to run the task processing as a service?
Nope. Need a user to be logged into the vault for tasks to be sent to that task host machine.
I agree, it's not good because someone must either go log in to the task host machine whenever it restarts (consider the inevitable Windows update the night before Admin takes a week vacation). The alternative is some mechanism that logs in a user after restart/boot, which is an inherent security risk. Pick your poison.
So far we have been using the manual log in option and I keep an eye on the machine to run the windows update before MS does it automatically for me.
