Search.exe - command line switch for column set
Discuss SolidWorks PDM
Hansjoerg
x 71
x 60
Unread post by Hansjoerg »
Since version 2021 you can predefine column sets in the PDM for e.g. the display of search results.
Is it possible to call these column sets with the Search.exe tool via command line parameters?
If this works I would put two different shortcuts for the Search.exe on the desktop.
1. for the search and display of models and drawings.
2. for the search and display of projects.
x 274
x 462
Re: Search.exe - command line switch for column set
Your best bet is to create a search and save it in your favorites. Then you could create a batch file to open up a saved search as described in this article:
https://www.cati.com/blog/running-epdm- ... mand-line/
