Document Manager Replace external references
ATANAS
Unread post by ATANAS »
Hi,
Has anybody succeeded in replacing external references FOR ASSEMBLY AND PART using document manager?
The below code works for drawing where GetAllExternalReferences4 is called. But according to the SW documentation this function should be called on drawings only and for part and assembly files GetExternalFeatureReferences2 should be used.
the code works with no errors but when i open the assembly file that is supposed to pint to a new referenced file location it still looks for the file at the old location.
Cheers,
Atanas
Public Sub UpdateReferences(strFromFile As String, strToFile As String)
Dim swDmApp As SwDocumentMgr.SwDMApplication4
Dim swDmDoc As SwDocumentMgr.SwDMDocument21
Dim searchOpts As SwDocumentMgr.SwDMSearchOption
Dim vDependArr As Variant
Dim vDepend As Variant
Dim i As Long
Dim brokenRef As SwDmReferenceStatus
Dim isVirtual As Boolean
Dim timeStamp As Double
Set swDmApp = ConnectToDm
For i = 0 To UBound(arFiles)
If LCase(Right(arFiles(i), Len(arFiles(i)) - InStrRev(arFiles(i), "."))) = "slddrw" Then 'the document is drawing
Set searchOpts = swDmApp.GetSearchOptionObject
searchOpts.SearchFilters = SwDmSearchFilters.SwDmSearchExternalReference
Set swDmDoc = OpenDocument(swDmApp, arFiles(i), False)
On Error Resume Next
vDependArr = swDmDoc.GetAllExternalReferences4(searchOpts, vBrokenRefs, vIsVirtuals, vTimeStamps)
If Err.Number > 0 Then MsgBox Err.Number
On Error GoTo 0
Else ' not a drawing- assembly or part
Dim l As Long
Dim dmExtRefOption As SwDMExternalReferenceOption2
Set dmExtRefOption = swDmApp.GetExternalReferenceOptionObject2
searchOpts.SearchFilters = SwDmSearchFilters.SwDmSearchForAssembly
dmExtRefOption.SearchOption = searchOpts
l = swDmDoc.GetExternalFeatureReferences2(dmExtRefOption)
vDependArr = dmExtRefOption.ExternalReferences
On Error GoTo 0
For Each vDepend In vDependArr
If InStr(vDepend, strFromFile) > 0 Then Exit For
Next vDepend
swDmDoc.ReplaceReference vDepend, strToFile
swDmDoc.Save
swDmDoc.CloseDoc
Next i
by andrmollo » Fri Sep 29, 2023 1:34 am
Hi!
Have you looked at codestack?
https://www.codestack.net/solidworks-do ... eferences/
Following that example I was able to do it for assembly and parts.
andrmollo
x 5
Re: Document Manager Replace external references
Unread post by andrmollo »
Hi!
ATANAS
It worked!
I came across this example but dismissed it as I thought it would work only on drawing files.
I should have known better than to dismiss code offered by Artem.
Thank you both!
