Macro for Toggling Transparency of Components
Library for macros
Slasher
x 39
x 20
Unread post by Slasher »
Hello forum,
My 1st post here! looking for a macro which I think might be helpful for all actually.
So you know how you can use tab and shift-tab to hide & unhide hovered components; love that feature, super convenient, right?
Can something like that be done but for transparency (basically a toggle)? Hover would be best, but I assume it won't be as easy? How about pre-selecting the component, press a key (assigned to the said macro), make the part transparent, click again and make it opaque? I searched for such a macro a bit, no luck.
Thanks in advance!
Vahid
by JSculley » Wed Oct 25, 2023 10:44 am
Slasher wrote: Mon Oct 23, 2023 6:20 pm Hello forum,
Thanks in advance!
Vahid
This is a one-liner macro. You can easily assign it to a hot key. Pre-selection of one or more components is required.
Dim swApp As Object
    swApp.RunCommand swCommands_e.swCommands_ChangeTransparency, ""
Answers: 16
x 22
x 500
Re: Macro for Toggling Transparency of Components
There's no need for a macro. Toggle transparency is already a button in the UI. You can map the command to a shortcut key.
Slasher
x 39
x 20
Hi Josh,
I'm using 2020 and transparency toggle or anything like that won't shop up in the commands (under keyboard tab in customize menu) when you search for it.
MattW
x 5
Unread post by MattW »
I think this shows up by default when you click on a part
x 2207
x 1860
According to the swamp the answer is no. It is an old thread, but has replies from the last few months.
https://r1132100503382-eu1-3dswym.3dexp ... 9ijKAr-pKg
If you are trying to write a macro, I think this is the call you are looking for.
https://help.solidworks.com/2020/englis ... Redirect=1
Slasher
x 39
x 20
MattW wrote: Tue Oct 24, 2023 4:21 pm I think this shows up by default when you click on a part
Yeah I am aware of that, but I'm trying to avoid the extra clicks. I like to be able to assign a key to it and toggle quickly between opaque and transparent, solidworks currently doesn't allow that, hence my inquiry about a macro that can do that.
Slasher
x 39
x 20
SPerman wrote: Tue Oct 24, 2023 4:32 pm According to the swamp the answer is no. It is an old thread, but has replies from the last few months.
Thanks for the link...for a second I thought I'm missing something after @josh comment, but yeah definitely you can't assign a hotkey to this command without a macro.
As for the api link, unfortunately I am not knowledgeable enough to write the macro :(
x 2207
x 1860
Slasher wrote: Tue Oct 24, 2023 7:13 pm Thanks for the link...for a second I thought I'm missing something after @josh comment, but yeah definitely you can't assign a hotkey to this command without a macro.
I went through the settings in SW and couldn't find it either.
x 868
SPerman wrote: Wed Oct 25, 2023 7:46 am I went through the settings in SW and couldn't find it either.
SPR184416 -- Unable to assign a hot key to "Change transparency" (short cut key quick )
Slasher
x 39
x 20
Found this thread from eng-tips which is about same request; but the link referenced there to the macro is dead
https://www.eng-tips.com/viewthread.cfm?qid=140985
Slasher
x 39
x 20
JSculley wrote: Wed Oct 25, 2023 10:23 am SPR184416 -- Unable to assign a hot key to "Change transparency" (short cut key quick )
Hello JSculley, where can I see a list of these SPRs. Do you have a link?
x 2207
x 1860
This will take you to the knowledge base. From there you can search for that SPR.
https://support.3ds.com/knowledge-base/
x 2207
x 1860
Based on that link, it is possible the creator of these forums could be the author of that macro.
@matt
x 868
Thanks in advance!
Vahid
Dim swApp As Object
Slasher
x 39
x 20
SPerman wrote: Wed Oct 25, 2023 10:37 am This will take you to the knowledge base. From there you can search for that SPR.
Nothing will show up when I look up this SPR:
Slasher
x 39
x 20
JSculley wrote: Wed Oct 25, 2023 10:44 am This is a one-liner macro. You can easily assign it to a hot key. Pre-selection of one or more components is required.
Dim swApp As Object
Thanks! I will give it a try, hopefully SOLIDWORKS add it with the hover functionality!
x 1214
x 2365
SPerman wrote: Wed Oct 25, 2023 10:41 am Based on that link, it is possible the creator of these forums could be the author of that macro.
@matt
That's a really REALLY old link. 20 years old or more. I think that's an address I had when I lived in Rochester. REALLY old. 20+ years.
x 2353
x 2008
matt wrote: Wed Oct 25, 2023 12:54 pm That's a really REALLY old link. 20 years old or more. I think that's an address I had when I lived in Rochester. REALLY old. 20+ years.
Verizon.net as your first website host Matt... <()> :lol:
Slasher
x 39
x 20
Can you dig up that macro for me please? Just kidding.
x 2207
x 1860
AlexLachance wrote: Wed Oct 25, 2023 1:12 pm Verizon.net as your first website host Matt... <()> :lol:
At least it wasn't a MySpace page. :)
x 1214
x 2365
They gave dialup customers FTP space. I had a website in 1995. I posted user group presentations. The whole format translated perfectly into blogs. This was back when Verizon was a regular phone company, before they became a wireless juggernaut.
