Hi All I 'm not sure where to look on how to Add a unique color to each Feature in a part, the reason is that when i export the part to Unreal it would then allow me to assign Unreal texture a lot more easier, This would also be useful with surfaces on the part. It has been a while since i made some macros and i know there is a API list of all the functions for parts etc.
I usually export the part as a step file, then import into Unreal using the Data Smith tool inside Unreal.
In the past i manually colored the parts in SolidWorks. In this macro I would automate this for each feature in the part and assign it a unique color.
Thanks for your input.
Creat a Macro to Add colors to each feature in a a part
- Craig Makarowski
- x 8
- x 73
- Stefan Sterk
- x 54
- x 81
Re: Creat a Macro to Add colors to each feature in a a part
Hi @Craig Makarowski, See code below.
Option Explicit
Dim swDoc As SldWorks.ModelDoc2
Dim R() As Double, G() As Double, B() As Double
Dim vMatVal(8) As Double
Dim i As Long: i = -1
Set swDoc = swApp.ActiveDoc
If swDoc Is Nothing Then End
If swDoc.GetType <> swDocPART Then End
Set swFeat = swDoc.FirstFeature
While Not swFeat Is Nothing
If swFeat.GetFaceCount <> 0 Then
i = i + 1
ReDim Preserve R(i)
ReDim Preserve G(i)
ReDim Preserve B(i)
GenUniqueColor R, G, B
vMatVal(0) = R(i) ' R
vMatVal(1) = G(i) ' G
vMatVal(2) = B(i) ' B
vMatVal(3) = 1 ' Ambient
vMatVal(4) = 1 ' Diffuse
vMatVal(5) = 0.5 ' Specular
vMatVal(6) = 0.3125 'Shininess
vMatVal(7) = 0 'Transparency
vMatVal(8) = 0 'Emission
swFeat.SetMaterialPropertyValues2 vMatVal, swInConfigurationOpts_e.swAllConfiguration, Nothing
Set swFeat = swFeat.GetNextFeature()
Wend
'swDoc.GraphicsRedraw2
Function GenUniqueColor(ByRef arrR() As Double, ByRef arrG() As Double, ByRef arrB() As Double)
reset:
Dim R As Double, G As Double, B As Double
R = Rnd: G = Rnd: B = Rnd
Dim i As Integer
For i = LBound(arrR) To UBound(arrR)
If Int(arrR(i) * 254) = Int(R * 254) Then
If Int(arrG(i) * 254) = Int(G * 254) Then
If Int(arrB(i) * 254) = Int(B * 254) Then
GoTo reset
Next i
arrR(UBound(arrR)) = R
arrG(UBound(arrG)) = G
arrB(UBound(arrB)) = B
End Function
- Craig Makarowski
- x 8
- x 73
Thank you very much that works excellent!!
- Craig Makarowski
- x 8
- x 73
Stefan Sterk wrote: ↑Thu Nov 23, 2023 7:09 pm Hi @Craig Makarowski, See code below.
2023-11-24-01-16-35.gifCode: Select all
Option Explicit Sub main() Dim swApp As SldWorks.SldWorks Dim swDoc As SldWorks.ModelDoc2 Dim swFeat As SldWorks.Feature Dim R() As Double, G() As Double, B() As Double Dim vMatVal(8) As Double Dim i As Long: i = -1 Set swApp = Application.SldWorks Set swDoc = swApp.ActiveDoc If swDoc Is Nothing Then End If swDoc.GetType <> swDocPART Then End Set swFeat = swDoc.FirstFeature While Not swFeat Is Nothing If swFeat.GetFaceCount <> 0 Then i = i + 1 ReDim Preserve R(i) ReDim Preserve G(i) ReDim Preserve B(i) GenUniqueColor R, G, B vMatVal(0) = R(i) ' R vMatVal(1) = G(i) ' G vMatVal(2) = B(i) ' B vMatVal(3) = 1 ' Ambient vMatVal(4) = 1 ' Diffuse vMatVal(5) = 0.5 ' Specular vMatVal(6) = 0.3125 'Shininess vMatVal(7) = 0 'Transparency vMatVal(8) = 0 'Emission swFeat.SetMaterialPropertyValues2 vMatVal, swInConfigurationOpts_e.swAllConfiguration, Nothing End If Set swFeat = swFeat.GetNextFeature() Wend 'swDoc.GraphicsRedraw2 End Sub Function GenUniqueColor(ByRef arrR() As Double, ByRef arrG() As Double, ByRef arrB() As Double) reset: Dim R As Double, G As Double, B As Double R = Rnd: G = Rnd: B = Rnd Dim i As Integer For i = LBound(arrR) To UBound(arrR) If Int(arrR(i) * 254) = Int(R * 254) Then If Int(arrG(i) * 254) = Int(G * 254) Then If Int(arrB(i) * 254) = Int(B * 254) Then GoTo reset End If End If End If Next i arrR(UBound(arrR)) = R arrG(UBound(arrG)) = G arrB(UBound(arrB)) = B End Function [/quote] Thank you very much :-)
- Stefan Sterk
- x 54
- x 81
Hi Craig, the code below will give a unique color to each component in a assembly. Thought I'd drop it here since you asked about it in our PMs.
' # Title: Random Colorize Components #
' # Version: 24.1.26 #
' # Author: Stefan Sterk #
Option Explicit
Dim swAsm As SldWorks.AssemblyDoc
Dim swCmpDoc As SldWorks.ModelDoc2
Dim Components() As SldWorks.Component2
Dim Component As Variant
If swDoc.GetType <> swDocASSEMBLY Then End
Set swAsm = swDoc
If swAsm.ResolveAllLightWeightComponents(True) <> 0 Then End
' Initilize color array
ReDim Preserve R(0)
ReDim Preserve G(0)
ReDim Preserve B(0)
Components() = swAsm.GetComponents(False)
For Each Component In Components
Set swCmpDoc = Component.GetModelDoc2
If swCmpDoc.GetType <> swDocASSEMBLY Then ColorComp Component
Next Component
Function ColorComp(vComp As Variant)
Dim swComp As SldWorks.Component2
Set swComp = vComp
Dim Index As Long
If UBound(R) <> 0 Then
Index = UBound(R) + 1
ReDim Preserve R(Index)
ReDim Preserve G(Index)
ReDim Preserve B(Index)
vMatVal(0) = R(Index) ' R
vMatVal(1) = G(Index) ' G
vMatVal(2) = B(Index) ' B
swComp.SetMaterialPropertyValues2 vMatVal, swInConfigurationOpts_e.swAllConfiguration, Nothing
End Function
reset:
Dim i As Integer
GoTo reset
Next i
End Function
