How to select coordinate system plane using API
Posted: Wed Dec 06, 2023 10:59 am
I am trying to select a plane of a created coordinate system and then normal to it. It only works manually doing it, but not using API!
Appreciate any help!
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Coordinate System1\YZ Plane", "COORDSYS", 0, 0, 0, False, 0, Nothing, 0)
swApp.RunCommand swCommands_NormalTo, ""
Part.ClearSelection2 True
