how to get 3D coordinates of a sketch segment in the global coordinate system?
mihkov
x 17
x 24
Unread post by mihkov »
Initial parameters: There is a test part file PRUG_test_dim_on_SM-FP. It has a sheet metal rectangle located in space not orthogonal to any of the sides - by accident.
Why sheet metal? To have a Boundary_Box sketch. Why a rectangle? To make the Boundary_Box sketch coincide with the edge of the rectangle.
In addition, there is a 2D sketch on this rectangle in which there is a line segment that coincides with the edge, and there is also a 3D sketch in which there is also a line segment that coincides with the edge.
Now I have 3 different sketches in which there are segments whose starting and ending points coincide with the edge of the rectangle.
Now if I programmatically get the coordinates of the beginning and end of these geometric objects in the global coordinate system, they will coincide and I will understand that I am defining them correctly.
Now the problem.
There is a GetCurveParams2 function that only works with edges. And it works perfectly, accurately producing the correct coordinates of the beginning and end of the edge (result 3 in the Immediate window).
There is a function Evaluate2 that should give the coordinates of a point on a segment, the point is specified as a percentage along the length of the segment from 0.0 to 1.0.
The Evaluate2 function works with Curve, which can be obtained from both a sketch segment and an Edge.
Using the Evaluate2 function I only get the first point (0.0) with the correct coordinates, and the end point (1.0) is somewhere far in space.
If I select a segment from any sketch and run Sub main_with_SketchSeg() then I get the result 1 from the Immediate window.
If I select an edge and run Sub main_with_edge() I get a semi-correct Curve-based result (2 in the Immediate window) and a correct Edge-based result (3 in the Immediate window).
How to correctly get 3D coordinates in the global coordinate system for the start and end points of a sketch segment?
Dim swApp As Object
Dim swSketchSeg As SldWorks.SketchSegment
Dim swEdge      As SldWorks.Edge
Dim swCurve As SldWorks.Curve
Dim startPoint As Variant
Dim endPoint As Variant
'====== Before running this module, select one straight edge
' Get the active SolidWorks application
' Get the active model
Set swModel = swApp.ActiveDoc
' Getting the selection manager
' Get the selected Edge
Set swEdge = swSelMgr.GetSelectedObject5(1)
If Not swEdge Is Nothing Then
    ' Get the curve object
         Set swCurve = swEdge.GetCurve
        get_coordinatsCurve swCurve
        get_coordinatsEdge swEdge
Else
    MsgBox "Nothing is selected, or the Edge selected is invalid.", vbExclamation
'====== Before running this module, select one sketch segment, and only a straight segment.
' Get the selected segment
Set swSketchSeg = swSelMgr.GetSelectedObject5(1)
If Not swSketchSeg Is Nothing Then
         Set swCurve = swSketchSeg.GetCurve
Else
    MsgBox "Nothing is selected, or the SketchSeg selected is invalid.", vbExclamation
Function get_coordinatsCurve(swCurve As SldWorks.Curve)
         If Not swCurve Is Nothing Then
             ' Setting parameters for evaluation on the curve
             Dim params(1 To 2) As Double
             params(1) = 0# ' Initial parameter
             params(2) = 1# ' End parameter
             ' Calculation of points on a curve using parameters
             startPoint = swCurve.Evaluate2(params(1), 0)
             endPoint = swCurve.Evaluate2(params(2), 0)
             ' Using the results
             Debug.Print "Result based on Curve and Evaluate2"
             Debug.Print "Start      = (" & startPoint(0) * 1000# & "/ " & startPoint(1) * 1000# & "/ " & startPoint(2) * 1000# & ") mm "
             Debug.Print "End        = (" & endPoint(0) * 1000# & "/ " & endPoint(1) * 1000# & "/ " & endPoint(2) * 1000# & ") mm "
End Function
Function get_coordinatsEdge(swEdge As SldWorks.Edge)
            Dim vCurveParam As Variant
            'Get points of edge
            vCurveParam = swEdge.GetCurveParams2
            'results
            Debug.Print "Result based on Edge and GetCurveParams2"
            Debug.Print "Start      = (" & vCurveParam(0) * 1000# & "/ " & vCurveParam(1) * 1000# & "/ " & vCurveParam(2) * 1000# & ") mm "
            Debug.Print "End        = (" & vCurveParam(3) * 1000# & "/ " & vCurveParam(4) * 1000# & "/ " & vCurveParam(5) * 1000# & ") mm "
End Function
GetCoordinatesOfEndpointsSketchSegment01.swp
(48 KiB) Downloaded 69 times
PRUG_test_dim_on_SM-FP.SLDPRT
(81.79 KiB) Downloaded 52 times
Answers: 16
x 22
x 514
Re: how to get 3D coordinates of a sketch segment in the global coordinate system?
Multiply the point by the inverse of the sketch's transform.
