Check delimiter through API
berg_lauritz
Answers: 6
x 439
x 233
Unread post by berg_lauritz »
I just wrote a quick and dirty macro to import some dimensions that you set in a .txt file (basically because the import equations option in Solidworks is simply SO BAD!). Now I am trying to change the delimiter to the one that is used on this machine - but nothing seems to work:
Dim ModelDocExtension As SldWorks.ModelDocExtension
    Set swModel = swApp.ActiveDoc
    Set ModelDocExtension = swModel.Extension
    Dim docUserUnit As SldWorks.UserUnit
    Set docUserUnit = swModel.GetUserUnit(swLengthUnit)
    Debug.Print "Decimal separator character: " & docUserUnit.SeparatorCharacter
This always returns
Decimal separator character: .
But the global decimal separator is actually a comma (I'm back in Germany here).
How do I access the global one?
by berg_lauritz » Wed Jan 03, 2024 8:27 am
gupta9665 wrote: Wed Jan 03, 2024 7:02 am Have you looked at swUserPreferenceToggle_e.swUseSystemSeparatorForDims method?
I did (here), but that's just the toggle & if it is activated.
But I did find the answer now after pursuing this further, I just needed a nudge from you @gupta9665, thank you!
This prints the character for dimensions:
Dim stringstatus As String
    stringstatus = swApp.GetUserPreferenceStringValue(swSeparatorCharacterForDims)
    Debug.Print stringstatus
It's hidden here:
https://help.solidworks.com/2021/englis ... lue_e.html
Answers: 26
x 442
x 460
Re: Check delimiter through API
berg_lauritz
Answers: 6
x 439
x 233
It's hidden here:
