Hello, I am on sw2018 I have an assembly with about 300 parts and want to check if it is fully symmetric about the center plane.
My first attempt was to run a basic assembly level symmetry check. This did not meet my needs because if a symmetrical part had its symmetry plane coincident with the symmetry check plane it would be flagged as asymmetric.
Next I made a new dummy assembly and inserted two copies of my real assembly. Then I applied a symmetry mate to these two assemblies. This was better because it removed the false positives and only showed truly asymmetric parts. However, I then have to run symmetry check on each flagged part to find the actual problem.
I noticed that running symmetry check on a part allows color option of coloring unique faces (which is what i really want for assembly). So I saved my dummy assembly as a part thinking I could run a check to find all problem faces all in one go. Unfortunately, symmetry check does not work on multi-body parts. Sigh.
I tried saving my real assembly as a part and creating an assembly mirror opposite hand version. Then did file compare geometry check between these two files, but it never completed and crashed.
I tried creating assembly cavity using the opposite hand version as the tool on the normal part. Got an error that said the model was empty even though I can visually see that there should be leftover geometry.
I am going to get through this by running a check on each flagged part individually, but wondering if there is a trick I missed? I wonder if there is a way to save out an assembly to surfaces only (like save as part with exterior faces, except keeping all faces).
- Board index CAD SolidWorks How To Questions
- Search
- It is currently Tue Dec 24, 2024 1:35 pm
- All times are UTC-05:00
Face based assembly symmetry check.
Jump to
- Welcome New Members
- ↳ Welcome
- ↳ Forum Rules
- CAD
- ↳ CAD Agnostic
- ↳ SolidWorks
- ↳ How To Questions
- ↳ SW General
- ↳ SolidWorks FAQ
- ↳ API
- ↳ Macro Library
- ↳ SolidWorks PDM
- ↳ 2D Drawings
- ↳ Routing-Electrical-Piping
- ↳ Surfacing
- ↳ SW Simulation
- ↳ SW Motion Analysis
- ↳ Enhancement Requests
- ↳ Solid Edge
- ↳ NX
- ↳ Onshape
- ↳ Creo
- ↳ Inventor
- ↳ Fusion 360
- ↳ KeyCreator
- ↳ Catia and 3DX
- ↳ IronCAD (CAXA)
- ↳ Shapr3D
- ↳ subD and Mesh
- ↳ Hardware
- ↳ Misc CAD
- ↳ Draftsight
- Other Technology
- ↳ Rendering and Motion
- ↳ 3D Scan
- ↳ AI and Related Tech
- Manufacturing
- ↳ 3D Print
- ↳ CAM
- ↳ PowerMILL
- ↳ Robotics
- Board Business
- ↳ Suggestions
- ↳ What's Wrong?
- ↳ What's New
- ↳ Events
- ↳ Media and Advertising
- Off Topic
- ↳ Kitty Dump
- ↳ Job Listings
- ↳ For Sale and Want To Buy
