Custom Property Tab Template -- Static Text
Posted: Wed Apr 10, 2024 7:13 am
by zwei
Is it possible to have static text on the custom property tab builder?
Basically, i am interested to add some static text such as title or instruction.
The closest workaround that i found so far is to use a empty groupbox but it does not look that good (and i am also slightly annoyed by the expand/collapse button that do nothing since it is a empty groupbox)
I am wondering is there any better approach that i am not aware of...
Re: Custom Property Tab Template -- Static Text
Posted: Wed Apr 10, 2024 7:20 am
by zwei
Oops..
I only stumble across this accidentally directly after i post the question...
There is a message section that can be used to display text on top
Not perfect... but good enough
https://help.solidworks.com/2021/Englis ... dfe9d8#Pg0
