https://r1132100503382-eu1-3dswym.3dexp ... nxzxw7z_6w
If interested, please vote for this.
Use same display state as original occurence
- x 2353
- x 2008
- x 804
- x 973
Re: Use same display state as original occurence
That would be useful....AlexLachance wrote: ↑Thu May 02, 2024 9:26 am https://r1132100503382-eu1-3dswym.3dexp ... nxzxw7z_6w
However, did you know that you can change the display state for multiple components all at once?
Simply SHIFT select (or CTRL select) multiple components, then RMB on them and select properties. If they are all the instances of the same part (which would be the case with a pattern), then you can select the display state and it will change for all of them at once.
- x 2353
- x 2008
Yes I knew about that, I'm just trying to avoid having to select them one by one. It's really not that big of a deal but it would save some time in some cases.DanPihlaja wrote: ↑Fri May 10, 2024 10:03 am That would be useful....
Would this do what you want?
- x 2353
- x 2008
