Vote to fix broken SW2024 "Enhancement"
Posted: Wed May 22, 2024 11:38 am
The new feature that allows adding units to a custom property in SW2024 has caused more problems than it solved for many users (see https://help.solidworks.com/2024/englis ... m_prop.htm if you aren't familiar with it).
Here is the link to vote to fix it, if anyone is interested: https://r1132100503382-eu1-3dswym.3dexp ... _uGMHhpQxg
Re: Vote to fix broken SW2024 "Enhancement"
Posted: Wed May 22, 2024 11:59 am
Voted. This is a good example of why things need to be tested throughly before being released lol.
Posted: Wed May 22, 2024 12:28 pm
Testing?
Let the user test it.
SW always has problem with UI.
Their developers might be using mind control instead of mouse and keyboard.
Posted: Thu May 23, 2024 12:13 am
by Alin
Just a note that arrow navigation is still possible in combination with the ENTER key. I tested that in SW 2024 SP2.0. and it works fine.
In a nutshell, press Enter after every edit, then use the arrows to move around.
Posted: Thu Aug 01, 2024 8:58 am
Glenn Schroeder wrote: Wed May 22, 2024 11:38 am The new feature that allows adding units to a custom property in SW2024 has caused more problems than it solved for many users (see https://help.solidworks.com/2024/englis ... m_prop.htm if you aren't familiar with it).
I downloaded and installed SW2024 sp 3.1 yesterday. I am happy to say that this issue is fixed. Maybe the one with the new method of re-attaching dimensions will be next?
Posted: Mon Aug 12, 2024 8:51 pm
by imaca101
Good luck, can't imagine Dassault would ever give an option for this kind of user interface behaviour - they never have before. The similar problem with the Property Manager where the completely useless drop down for selecting units blocks input boxes underneath for me is much more annoying and has been around forever.
