Hello,
For years I've been using a macro to export a SW drawing file as in pdf and dxf format in one go.
I use it daily and it's saved me so much time over the years.
I'd love to add an extra level of function to it, whereby any multi-sheet drawings are exported as individual dxf files with the sheet name as a suffix of each file name rather than the default numerical prefix.
I've tried editing the macro to add this, but my knowledge is negligible and have got nowhere.
I'll paste the existing code below, and if anyone can help me achieve what I'm after I'll be extremely grateful.
Thanks,
Martin
Option Explicit
Dim sPathName As String
Dim nErrors As Long
Dim nWarnings As Long
Dim nRetval As Long
Dim bShowMap As Boolean
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swExportData As SldWorks.ExportPdfData
Dim filename As String
Dim boolstatus As Boolean
Dim lErrors As Long
Dim lWarnings As Long
Dim bRet As Boolean
Set swModel = swApp.ActiveDoc
' Strip off SolidWorks drawing file extension (.slddrw)
' and add DXF file extension (.dxf)
sPathName = swModel.GetPathName
sPathName = Left(sPathName, Len(sPathName) - 6)
sPathName = sPathName + "dxf"
' Show current settings
' Turn off showing of map
bShowMap = swApp.GetUserPreferenceToggle(swDXFDontShowMap)
Set swModelDocExt = swModel.Extension
Set swExportData = swApp.GetExportFileData(swExportPDFData)
filename = swModel.GetPathName
filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
If boolstatus Then
MsgBox "A .PDF and a .DXF have been saved." & vbNewLine
Else
MsgBox "I didn't like that!" & lErrors '
swApp.SetUserPreferenceToggle swDXFDontShowMap, False
bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
If bRet = False Then
nRetval = swApp.SendMsgToUser2("Problems saving file.", swMbWarning, swMbOk)
' Restore old setting
swApp.SetUserPreferenceToggle swDXFDontShowMap, bShowMap
pdf & dxf export adding sheet name to filename for multi-sheet
- x 1
Hi Martin,Martin Abbott Design wrote: ↑Wed Jul 03, 2024 5:52 am Hi AlexB, thanks for the link,
Funnily enough I had been looking at that very page and trying to tweak the above code to pull through the vSheetName parts into my existing macro. It was after many fruitless attempts that actually led me here to get some help from someone who knows what they're doing, as this is apparently beyond my abilities!
Martin
See if this does what you're looking for. I added a few lines to your code:
Option Explicit
Dim nErrors As Long
Dim nRetval As Long
Dim lErrors As Long
Dim bRet As Boolean
Dim i As Integer
Dim vSheetNames As Variant
Dim swDraw As DrawingDoc
Dim bSheetExportOption As Integer
sPathName = Left(sPathName, Len(sPathName) - 7)
bSheetExportOption = swApp.GetUserPreferenceIntegerValue(swDxfMultiSheetOption)
Set swExportData = swApp.GetExportFileData(swExportPdfData)
swApp.SetUserPreferenceToggle swDXFDontShowMap, True
swApp.SetUserPreferenceIntegerValue swDxfMultiSheetOption, swDxfActiveSheetOnly
'bRet = swModel.SaveAs4(sPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
Set swDraw = swModel
vSheetNames = swDraw.GetSheetNames
For i = 0 To UBound(vSheetNames)
bRet = swDraw.ActivateSheet(vSheetNames(i))
bRet = swModel.SaveAs4(sPathName & "_" & vSheetNames(i) & ".dxf", swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
Next i
If boolstatus And bRet Then
Else
swApp.SetUserPreferenceIntegerValue swDxfMultiSheetOption, bSheetExportOption
Re: pdf & dxf export adding sheet name to filename for multi-sheet
There's already a pretty good example on the api help site:
https://help.solidworks.com/2020/englis ... ple_VB.htm
- x 1
Martin
Martin
Martin
Option Explicit
Dim nErrors As Long
Dim nRetval As Long
Dim lErrors As Long
Dim bRet As Boolean
Dim i As Integer
Next i
Else
- x 815
- x 993
I don't know if this setting will affect a macro's output or not...
But what do you have for this setting? On mine, that setting saves out the files as
00_filename
01_filename
02_filename
etc...
and it doesn't use sheet name.
So maybe it isn't related.
00_filename
01_filename
02_filename
etc...
It does need to be selected to "save the active sheet only" and I've got that being set in the macro above in order to guarantee it outputs just one sheet at a time. When saving via the API, the filename provided to the save method will be what it's saved as. In this case, "fileName_sheetName". This does require looping through and activating each view before saving though which takes a bit of time, especially for larger drawings.DanPihlaja wrote: ↑Wed Jul 03, 2024 1:35 pm I don't know if this setting will affect a macro's output or not...
00_filename
01_filename
02_filename
etc...
- x 1
AlexB, that's absolutely perfect!
Thank you so much!
Thank you so much!
