Display "feature"
Posted: Sat Jul 27, 2024 10:25 am
by doobes
Hey all,
I've run into this aa couple of times in the past, and never been able to figure out why.
I'm modeling a blower fan for my 3D printer based off of a STL file downloaded from Thingiverse.
I've done this a gazillion times, so it's all good.
I'm near the end and it looks like this:
I insert a couple of through holes for a M3 screw and the thing disappears:
If I turn on the wirebody display it's all there:
Any idea as to why it's doing this?
Thanks
Re: Display "feature"
Posted: Sat Jul 27, 2024 10:35 am
by doobes
LOL.
If I delete the through holes and then recreate them the issue goes away....
grumph
Posted: Mon Jul 29, 2024 8:56 am
See if anything at viewtopic.php?f=17&t=98&p=883#p883 will help. I'd start with the first thing mentioned there.
Posted: Mon Jul 29, 2024 1:52 pm
by DanPihlaja
Try hiding and then showing the body.
Has happened to me a couple of times (assuming it is the same thing).
Just Hide, then re-show resets it.
Posted: Mon Jul 29, 2024 6:24 pm
by len_1962
Control-Q
Posted: Mon Jul 29, 2024 8:47 pm
by doobes
I beat my head against this all day today.
It's an artifact of an oldish video card and trying to reverse engineer a STL file in a part.
Once I deleted the imported STL object from the part, it all was fine.
Henceforth I'll probably do this as an assembly using the STL reference. I found it all works much better that way.
I did turn off enhanced graphics. Thanks for that tip.
Cheers
